Woodcut Tools Tru-Grind Original Sturdy Rest
- Made from thick plate steel to eliminate flexing and vibration
- Compatible with the Tru-Grind sharpening system
- Easily mounts under a standard bench grinder
- Unique design allows the rest to pivot out of the way when not in use
- Ideal for sharpening chisels, plane blades, and woodturning scrapers
- Ensures consistent and accurate grind for precise and repeatable result
Woodcut Tools Tru-Grind Tool HolderSpecial Price £87.98 £73.32 was £109.98 £91.65 Save £22.00 £18.33
Woodcut Tools Tru-Grind Sturdy Rest PremiumSpecial Price £76.98 £64.15 was £109.98 £91.65 Save £33.00 £27.50
Woodcut Tools Tru-Grind Original Base SlideSpecial Price £62.98 £52.48 was £69.98 £58.32 Save £7.00 £5.83
The Woodcut Tools Tru-Grind Original Sturdy Rest is an essential addition to any woodworker's toolkit, designed to provide stability and precision during the sharpening process. Made from thick plate steel, this sturdy rest eliminates flexing and vibration, ensuring a consistent and accurate grind.
It is compatible with the Tru-Grind sharpening system and can be easily mounted under a standard bench grinder. The unique design allows the rest to pivot out of the way when not in use, making it versatile and convenient. This tool is ideal for sharpening a variety of tools, including chisels, plane blades, and woodturning scrapers, making it a valuable asset for achieving precise and repeatable sharpening results.
