Woodcut Tools Tru-Grind Sharpening System & 25mm CBN Grinding Wheel
- Tru-Grind Sharpening System
- Effective and easy-to-use tool grinding jig
- A whole range of grinding angles and profile possible
Customers Also Bought
Package comprises a Tru-Grind sharpening system and a Woodcut Tools Tru-Grind CBN grinding wheel.
Attaining the correct profiles on your turning tools could transform your turning, and the advantages of using a jig are that the angles are easily repeatable and its use removes less material at each sharpening. The tool holder clamps gouges, skew chisels, parting tools and scrapers, making it possible to present them to the wheel at the correct angle. The jig can produce a classic fingernail profile with swept-back wings on your bowl gouges, with one perfect single facet bevel. Even better, a particular chosen profile or angle is easy to reproduce time after time.
Woodcut Tools Tru-Grind CBN Grinding Wheel
150mm x 25mm x 12.7mm bore, 180 grit. Tru-Grind Cubic Boron Nitride(CBN) grinding wheels are a revelation for the sharpening of HSS turning tools. CBN abrasive is a similar product to synthetic industrial diamonds, but a CBN wheel is far better suited for sharpening high speed steels and will withstand the friction from grinding, with much less heat produced than with a diamond wheel. They produce hardly any sparks, cut quickly and efficiently and will last for many years. Plus, because it will withstand the friction, the wheel doesn't wear and therefore the jig will not need to be reset. No dressing is required and they leave a nice fine and even sharp edge.
- Accurately and consistently, reproduce profiles
- Sharpen tools without grinding them away
- Woodcut Tools Tru-Grind CBN Grinding Wheel
- 150mm x 25mm x 12.7mm bore, 180 grit
- Smooth grinding from 100 to 3,500rpm
- Cool cutting no burnt or blue edges
- No wear, so no resetting of your jigs
- Only light pressure required
- No dressing or conditioning required
