WoodSpur A4 Stainless Steel Torx Head Screw Assortment (1,000 Pieces)
505591
From £59.98 £49.98
  • Buy 5 for £56.98 £47.48 each and save 5%
  • Buy 10 for £53.98 £44.98 each and save 10%
  • Buy 15 for £50.98 £42.48 each and save 15%
In Stock
- get it Wednesday 17th Apr, order within and choose Premium delivery. Delivery info
  • A4 marine grade stainless steel Trade Pack for outdoor and marine use
  • Needle sharp, self-cutting tip that requires no pilot hole or pre-drilling
  • Wax lubricated threads, self-countersinking head
  • Convenient carrying case, with handle
  • T15, 20 and 25 Torx bits included
  1. WoodSpur A4 Stainless Steel Torx Head Screw Assortment (1,000 Pieces)
Total:
£111.52 £92.93
The features that set WoodSpur apart...
Gold zinc plated steel finish screws with high resistance to corrosion. Suitable for interior use
in soft or hard wood, chipboard, OSB or MDF.
The head
Increasing the size of the head where it meets the body makes these screws much stronger. This minimises the risk of the head shearing under the final tightening torque.
The tip
The tip cuts as it penetrates and the initial portion of the thread engages immediately. The sharp point helps when placing the screw and prevents skating.
A project away from the bench or workshop often requires a multitude of different sized screws. The 'WoodSpur' Trial pack of stainless steel screws offers the ideal solution, as all common sizes are conveniently stored in one robust storage case, making transportation child’s play...much easier in fact than carting around innumerable boxes of assorted sizes.
A4 (also known as Marine Grade) stainless steel contains a small amount of molybdenum, which creates a particular type of steel having a much higher resistance to surface corrosion when compared with standard A2 stainless steel. The screws have a Torx head almost ensuring the elimination of 'cam out', where the screwdriver is liable to slip under pressure, damaging both the screw head and the bit. Screw threads are also wax lubricated for almost effortless driving into most timbers. These screws are suitable for all outdoor projects such as garden furniture, timber framing, sheds as well as boat building and renovation. As A4 marine grade stainless steel screws they are needle sharp and have a self-cutting tip that requires no pilot hole or pre-drilling.
An extra addition to the set is the Pan Head screw in 4 x 35mm. These screws are also suitable for outdoor projects. The pan head makes them perfect for attaching guttering and down pipes etc.
The pack contains 1,000 screws of the following quantities:
3.5 x 25mm, T15 Torx head, 200
3.5 x 40mm, T15 Torx head, 200
4 x 20mm, T20 Torx head, 200
4 x 30mm, T20 Torx head, 100
4 x 40mm, T20 Torx head, 100
4 x 50mm, T20 Torx head, 100
5 x 60mm, T25 Torx head, 50
4 x 35mm, Pan Head T20, 50
4.70 23
