WoodSpur Pozidrive Self Countersinking Wood Screws
- Top quality zinc plated wood screws with a self countersinking head
- Deep sharp threads that cut into the wood, not forcing through
- Penetrating tip that requires no pilot hole or pre-drilling
- Heat treated to ensure they are hard and resistant to snapping
- Available in box quantities of 200 or 500.
- For use in soft or hard wood, MDF or chipboard
- Pozidrive heads and wax lubricated for the easiest driving
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £12.38 £10.32 was £12.88 £10.73 Save £0.50 £0.42
The features that set WoodSpur apart...
Gold zinc plated steel finish screws with high resistance to corrosion. Suitable for interior use
in soft or hard wood, chipboard, OSB or MDF.
The head
Increasing the size of the head where it meets the body makes these screws much stronger. This minimises the risk of the head shearing under the final tightening torque.
The tip
The tip cuts as it penetrates and the initial portion of the thread engages immediately. The sharp point helps when placing the screw and prevents skating.
Zinc yellow passivated plated wood screws with a self countersinking head. They have deep sharp threads that cut into the wood and divide the fibres rather than simply forcing their way through, and a penetrating tip requiring no pilot hole or pre-drilling. These screws are heat treated to ensure they are hard and resistant to snapping. Lubricated with a wax coating to minimise heat and aid insertion. For trouble free fastening in soft or hard wood, MDF or chipboard. Precision Pozidrive heads. Volume discounts apply to a mix of these items. N.B 100m lengths are partial threaded. Supplied in box quantities of 200 or 500.
Drive Type | Pozi |
