Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Woodspur Torx Trade Pack & Stanley FatMax Pro Organiser
Code: 720611
  • WoodSpur Torx Head Premium Wood Screws
  • 10 of the most popular sizes, 200 screws of each
  • Deep sharp threads with self-countersinking head
  • Penetrating tip that requires no pilot-hole or pre-drilling
  • Wax lubricated for less effort when driving
  • Axminster Trade Torx Strip 10 Piece TiN Coated 1/4" hex Bits
  • TiN coating for increased wear resistance
  • 25mm bits in plastic strip carrier
  • Torx drive: 2 x T15, 3 x T20, 3 x T25, 2 x T30
  • Stanley FatMax Deep Pro Organiser
  • 10 removable storage compartments
  • Strong polypropylene construction
  • Transparent lid with waterproof seal
  • Secures with 2 metal latches
  • Show More
£69.96 (£58.30 Ex. VAT)
Out of stock
Sorry, this product is no longer available.
See Alternative Options
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Package comprises 2,000 WoodSpur torx head premium wood screws, an Axminster Trade torx strip with 10 screwdriver TiN coated bits and a Stanley FatMax Deep Pro organiser.
Tried, tested and immensely popular, these zinc plated wood screws feature a self-countersinking head. They have deep sharp threads that cut into the wood rather than simply forcing their way through. With their sharp penetrating tip these screws do not require a pilot-hole or pre-drilling. They are heat treated to ensure they are hard and resistant to snapping. Lubricated with a wax coating to minimise heat and aid insertion. Woodspur screws perform brilliantly in soft or hard wood, MDF or chipboard. The torx heads virtually eliminate cam-out, making them an excellent choice when using a cordless screwdriver.
2,000 screws as follows:
3 x 12mm x 200
3 x 16mm x 200
3.5 x 20mm x 200
3.5 x 35mm x 200
4 x 25mm x 200
4 x 40mm x 200
4.5 x 50mm x 200
5 x 45mm x 200
5 x 60mm x 200
6 x 100mm x 200
Axminster Trade Torx Strip 10 Piece TiN Coated 1/4" Hex Bits
A useful set of trade rated, TiN coated, high quality screwdriver bits, in a handy plastic strip holder, covering all common screw sizes: 2 x T15, 3 x T20, 3 x T25 and 2 x T30
The Stanley Deep Pro organiser comes with 10 removable storage compartments. It has a transparent lid with a waterproof seal. The textured polypropylene handle offers a secure grip and the heavy duty metal latches ensure the organiser will not accidentally fall open. Size: 446 x 356 x 116mm deep.
Promo
WoodSpur screws
The features that set WoodSpur apart...
Gold zinc plated steel finish screws with high resistance to corrosion. Suitable for interior use in soft or hard wood, chipboard, OSB or MDF.
The head
By increasing the size of the head where it meets the body makes these screws much stronger. This minimises the risk of the head shearing under the final tightening torque.
The head
The tip
The tip cuts as it penetrates and the initial portion of the thread engages immediately. The sharp point helps when placing the screw and prevents skating.
The tip
The thread
After plating, the screws undergo a further coating to reduce friction. Lower friction needs less power, meaning more screws driven on a single battery charge. The thread slices effortlessly through the timber without tearing the fibres, making for a much stronger fixing.
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
