Benchtop and brilliant
A compact and considered bench drill, offering impressive precision, accuracy and user safety at this size.
Buy with confidence
Genuine MSK Ball Bearings
Genuine NSK Ball Bearings
The spindle runs in genuine NSK ball bearings – known for their premium quality. The result is accurate drilling and low vibration, enhancing the overall precision of your work.
Enhanced safety system
Enhanced Safety System
The electronically interlocked chuck guard and integrated belt cover safety switch prevent the machine from being accidentally turned on or running with the cover open, ensuring maximum safety.
Multi-Vee Belts
Multi-Vee Belts
Multi-vee type belts provide maximum grip and low vibration, contributing to the drill's overall smooth and stable performance.
Improved depth stop
Improved Depth Stop
The improved depth stop allows for easy adjustment, enabling precise control over drilling depth for consistent results.
Polished cast iron table
Polished Cast Iron Table
The (290 mm x 290 mm / 345 mm x 345 mm / 475 mm x 425 mm*) cast iron table provides a strong and rigid work surface, ensuring stability and durability during drilling operations.
Rack and Pinion Table Adjustment
The rack and pinion mechanism provides quick and easy table adjustments, making it simple to position your workpiece accurately.
One-piece cast iron handle
One-Piece Cast Iron Handle
With soft rubber grips, the cast iron handle is comfortable to use, reducing user fatigue during extended use
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The Axminster Professional AP20BD Bench Drill 230V is a robust and versatile machine designed to meet the needs of any workshop. This drill features a precision spindle running in genuine NSK ball bearings, ensuring accurate drilling and low vibration. The multi-vee type belts provide maximum grip and low vibration, contributing to the smooth operation of the machine. The spindle assembly is a good fit into the headstock, enhancing the overall stability and accuracy of the drill.
Safety is a top priority with the AP20BD. It comes equipped with an electrically interlocked chuck guard that prevents the machine from being accidentally turned on, and an integrated belt cover safety switch that stops the drill from running with the cover open. Additionally, the adjustable LED work lamp provides excellent visibility of the workpiece, ensuring precise and safe drilling operations.
The ergonomic design of the AP20BD includes a one-piece cast iron handle with soft rubber grips for comfortable and smooth operation. The quality 1-16mm keyless chuck allows for quick and easy changing of drill bits, while the rack and pinion table adjustment ensures quick and easy table adjustments. Plus, with the improved depth stop design, you can make easy adjustments for precise drilling depths. Its compact design makes it an ideal addition to any workshop, offering both functionality and convenience.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 670 mm x 360 mm x 1,020 mm
Power 750 W
Rating Frequent Use
Table Size 290 mm x 290 mm
Table Tilt 45 - 0 - 45
Chuck Capacity 1 mm to 16 mm
Chuck Type keyless
Throat Depth 178 mm
Plug Fitted UK 3 pin plug
Model AP20BD
Base Size 450 mm x 270 mm
Chuck Travel 80 mm
Diameter of Column 80 mm
Max Chuck to Base 500 mm
Max Chuck to Table 325 mm
Max Drilling Mild Steel 20 mm
Morse Taper 2 MT
Nett Weight 82 kg
Speed Range 120 - 2,580 rpm
Spindle Taper 2 MT
Voltage 230 V
EAN Barcode 5052511136346
