Robust yet compact
A heavy duty machine, the AP25BM is ideal for a busy workshop and will offer years of dependable service.
Axminster Professional AP25BM Bench Morticer
Buy with confidence
Cast iron construction
The AP25BM Bench Morticer is produced almost entirely from cast iron, making this a strong and durable machine.
Smooth operation
Smooth, one handed operation
Easily control the longitudinal and lateral table movement with one hand wheel.
Adjustable work stops
With lateral stops for repeat mortising and a depth stop which includes a haunch stop, the AP25BM can be used to produce a number of different joints.
Gas strut assisted head
Benefit from reduced fatigue and “parking” of the headstock in any position, thanks to the gas strut assisted headstock travel.
Effective timber clamp
The multiple position material clamp can accommodate a range of workpiece widths, enhancing the versatility further.
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The AP25BM is a robust, compact bench mounted chisel morticer, produced almost entirely from cast iron. This strong, heavy-duty construction gives the machine capacities of 25mm in softwood and 19mm in hardwood. A single handwheel controls both longitudinal and lateral table movement. This system makes controlling the movement a breeze. The table has a tall back fence, with lateral stops for repeat mortising. The depth stop includes a haunch stop. The multiple position material clamp can accommodate different workpiece widths. A gas strut provides smooth downward travel of the headstock and also allows headstock parking in any position. There is an optional floor stand, plus also a very useful door mortising attachment.
This machine is well suited to a busy workshop and will provide many years of accurate and trouble-free service. It accepts chisels with either 3/4 or 13/16 shanks.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 460 mm x 515 mm x 1,000 mm
Power 750 W
Rating Frequent Use
Plug Fitted UK 3 pin plug
Model AP25BM
Centre of Chisel to Back Fence 110 mm
Chisel Stroke 125 mm
Lateral Table Movement 100 mm
Longitudinal Table Movement 410 mm
Max Chisel Size Hardwood 19 mm
Max Chisel Size Softwood 25 mm
Max Height of Timber 190 mm
Nett Weight 85 kg
Voltage 230 V
EAN Barcode 5052511124800
  • UK Mainland - £70
