Axminster Woodturning Pen Reamer
From £3.28 £2.73
5 Reviews
  • Create perfectly precise pens and pencils
  • Precision engineered pen reamers
  • Use in conjunction with the Axminster Woodturning Pen Trimmer
The Axminster Woodturning Pen Trimmer and Reamers is a unique system designed to enable you to create perfectly precise pens and pencils. The Pen Reamers are available to purchase individually; choose between a variety of sized pen reamers to suit a wide range of pen and pencil kits.
Create perfectly precise pens and pencils every time with the Axminster Woodturning Pen Trimmer and Reamer system. The process of making beautiful, custom-made pens and pencils requires precision when prepping the blank and brass insert tube. Once the brass tube is glued inside the blank, it's crucial that the blanks are trimmed perpendicular to and perfectly flush with the ends of the insert tube. If not achieved, then you run the risk of there being gaps in the finished product and parts of the assembly not coming together well. The Axminster Woodturning Pen Trimmer and Reamers precisely trim your blank, making sure that it is square with both ends of the insert tube; as well as removing excess glue. Helping to ensure your pen kit and blank fits seamlessly together.
Create bespoke Pen and pencils to write home about with Axminster Woodturning.
N.B. The diameter size on the reamers indicates the size of drill bit required/used to drill the hole into your blank.
British Made British Made
5.00 5
