Axminster Woodturning
Axminster Woodturning Replacement Cutter for Pen Trimmer
SKU: 110712
£12.78
£10.65 Excl. VAT
  • Spare cutter for the Axminster Woodturning Pen Trimmer and Reamer Set
  • Stainless Steel and carbide tipped
  • Features high top rake angle for accurate and smooth results
Spare cutter for the Axminster Woodturning Pen Trimmer & Reamers Set (sold individually).
Made entirely from Stainless Steel, the cutters are also carbide tipped and feature a high top rake angle to give clean, accurate and smooth results, cutting effortlessly through a variety of materials wood, polyester, acrylic and more.
The cutter is attached to the trimmer within the pen trimmer and reamer set, via a screw. Note the trimmer requires two cutters.
The carbide tipper cutter is designed to be long lasting. If the edge does dull, it can be removed via the supplied hex key, and refreshed.
Web Attribute Set Miscellaneous Woodturning
EAN Barcode 5052511133857
