Axminster Woodturning Tool Posts
From £6.14 £5.12 was £8.78 £7.32 Save £2.64 £2.20
  5. Half Star
132 Reviews
  • Stainless steel round bar threaded to accept Evolution Series Tool Rests
  • Separate tool rest makes system economical
  • Tool post fully interchangeable with all tool rests
  • Post diameters available to suit many lathes
  • 12mm (81mm long) 16mm (110mm long) 19mm (115mm long)
  • 25mm (140mm long), 1" (128 or 180mm long) & 30mm (180mm long)
For the smoothest turning
The Axminster Woodturning Tool Rest System is made entirely of stainless steel which means it's corrosion and rust free. The chisel glides seamlessly across the rounded bar without any nicked interruptions.
There are two simple steps...
The stainless steel round bars form the perfect tool rests and screw into the posts. Choose a selection of straight and curved rests - plus a mounting plate - to suit all your turning projects. Each of the accessories will fit a single tool post so it's easy to swap between them as you turn!
Axminster Woodturning Traditional Tool Rests are also available. These feature a large, round, hardened steel bar which is welded on top of a cast steel rest.
1. Select a post
Choose a diameter to suit your lathe
  • 12mm x 81mm long
  • 16mm x 110mm long
  • 19mm x 115mm long
  • 25mm x 140mm long
  • 25.4mm x 128mm long
  • 25.4mm x 180mm long
  • 30mm x 180mm long
Buy tool rests
2. Choose your rests or mounting plate
  • 100mm - for working in confined spaces, ideal for box making
  • 150mm - a middleman for general size turning!
  • 200mm - for gaining more access and supporting the chisel when turning deep inside vases and other hollow forms
  • 250mm - long length allows for deep support for the chisel inside bowls or longer pieces between centres
  • 300mm - available in the Axminster Woodturning Traditional Tool Rest range
  • S Shaped - gain greater control and get closer to the bowl when turning
  • Mounting plate - useful for when you're carving, drilling, finishing etc
Buy accessories
Your tool rest is the point of contact between you, the lathe, the tool and the work. It is important that the tool has the smoothest possible transit along the rest. Any bumps, ridges or hollows soon take the pleasure out of turning. Most standard tool rests are cast iron or relatively soft steel. Generally these rests soon develop nicks along their length and require occasional draw filing to bring them back into a useable condition. The Axminster Evolution Tool Rest System overcomes this problem.
In order to make the system as economic as possible Axminster Evolution produces the tool rests and tool posts as separate items. The stainless steel tool post screws into the tool rest. This means a single tool post to fit into your lathe will fit any of the four lengths of tool rest. Additional tool rests simply screw onto the tool post. If you own a second lathe requiring a different diameter tool post, then the purchase of a second tool post allows you to use all your existing tool rests. Spanner flats ground onto the tool post help fitting or removing the tool rest.
The first step is to choose a tool post to suit your lathe.
Tool post diameters are 12mm x 81mm long, 16mm x 110mm long, 19mm x 115mm long, 25mm x 140mm long, 1" x 128 or 180mm long and 30mm x 180mm long.
British Made British Made
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.73 132
