Axminster Workshop Aluminium Sash Clamp
- Lightweight, fully adjustable cast aluminium clamps
- Clamp faces are 50mm deep and 45mm wide
- Aluminium feet provide stability and prevent tipping
- Perfect for lighter projects and available in various sizes
Axminster Workshop Metric Vice-Versa Tape - 8mSpecial Price £9.98 £8.32 was £13.38 £11.15 Save £3.40 £2.83
Axminster Workshop Non Stick Dowel & Biscuit Glue BrushSpecial Price £5.16 £4.30 was £6.88 £5.73 Save £1.72 £1.43
Axminster Workshop Silicone Glue Brush KitSpecial Price £14.95 £12.46 was £18.68 £15.57 Save £3.73 £3.11
Axminster Professional D4 PU Adhesive 1kgSpecial Price £10.90 £9.08 was £15.58 £12.98 Save £4.68 £3.90
Our aluminium sash clamps have been fully tested and proved in our own workshop. They are lightweight, easy to manoeuvre and available in capacities up to 1,500mm. Ideal for lighter projects, they can be used alone or with Axminster Professional Sash Clamps for heavier tasks.
The heads and tail slides are cast aluminium, powder coated and feature good sized faces 50mm deep and 45mm wide.
The bars are a heavy gauge aluminium extrusion measuring 35mm x 22mm. Cast aluminium feet provide stability and prevent tipping, adding height for easy handle winding. Fully adjustable, they lock in 25mm increments. The threaded spindles are 12mm diameter with an Acme thread to allow for maximum force to be applied.
Available in clamping capacities of 600mm, 900mm, 1,200mm and 1,500mm sizes.
Maximum clamping pressure is 400kg.
Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
Clamping Pressure | 400 kg |
