Woodworking Wisdom
Two Tools, One Craft | Arbortech Power Carving Tools
two tools - one craft
Arbortech Ball Gouge vs Arbortech Precision Carving System
Are you wondering which Arbortech power carving tool to choose? Maybe you may need both! This guide will help you break down the differences and highlight what kind of power carving projects you can tackle with each tool. Let's dive in and explore both Arbortech power carving tools.
Arbortech Ball Gouge - a powerhouse for hollowing
Arbortech Ball Gouge - a powerhouse for hollowing - product
Introducing the Ball Gouge, Arbortech’s original freehand power carving hero. It’s a 30mm spherical cutter attachment, designed for quickly shaping and hollowing out concave forms, think wooden bowls, spoons, or sculptural pieces. It’s a go-to for shaping organic forms, where you want smooth flowing movement and a clean finish. Beyond hollowing, it can produce a distinctive, chisel-like texture when moved across wood surfaces.
Arbortech Ball Gouge - hollow form
Arbortech Ball Gouge - sculpture carving
Arbortech Ball Gouge - spoon carving
Projects for the Ball Gouge
Arbortech Precision Carving System - Detail, Texture and Finesse
Arbortech Precision Carving System - Detail, Texture and Finesse product
The Precision Carving System is designed for finer, more intricate work. Rather than a single cutter, it’s a modular kit which mounts via a slimline universal base, allowing greater visibility and reach, especially in tight areas. Interchangeable heads let you switch between cutting and sanding in seconds. It's ideal for adding texture, lettering, and finishing small areas with precision.
Precision carving - Gouge
Precision carving - Carve
Precision carving - Sand
The kit includes:
  • 15mm Precision Ball Gouge, like a mini version of the standard Ball Gouge
  • Precision Barrel Carver, excellent for straight-line carving or tight inside curves
  • Precision Drum Sander, perfect for finishing with a smooth, controlled touch
Projects for the Precision Carving System
Side by Side Comparison
Feature Ball Gouge Precision Carving System
Cutter Size 30mm 15mm (Ball Gouge), plus Barrel Carver & Drum Sander
Attachments Single cutter Modular – 3 heads (cutting & sanding)
Primary Use Shaping, hollowing, flowing forms Detailing, fine texturing, finishing
Compatibility Power Carving Unit or 100–115mm angle grinders Power Carving Unit or 100–115mm angle grinders
Ideal Projects Bowls, spoons, sculptures Pinch bowls, surface texture, fine relief carvings
Which Should You Choose?
If your main goal is hollowing out wood quickly, especially from bowls, trays or sculptural pieces, the Arbortech Ball Gouge is the one to start with. It's quick, effective, and very satisfying to use. However, if you're more interested in detailed textures, fine carving, or finishing work, the Arbortech Precision Carving System gives you a full set of smaller-scale tools to achieve this. The two tools do work brilliantly together, and if you’re doing a variety of carving, you’ll likely end up reaching for both, for many power carving projects.
Discover more Arbortech Tools, start with our blog, Choosing the right Arbortech blade.
Leave a comment
