Woodworking Wisdom
Coffee Table - Freehanding with a router
With the jointing now completed, the next stage is to look at the top corners of each leg, as the glass will sit inside the leg in a sort of square rebate and, somehow, this section has to be removed.
Corner marked out Corner marked out
Chopping end grain out by hand is a complete pain and a task well avoided, so the only real solution was to use the router to machine it away.
Framework on assembly table Framework on assembly table
With the framework still cramped together and mounted on the assembly table, the only way to provide sufficient surface area to balance the router was to make a cunning, little jig which in turn was cramped onto two adjacent sides of the offending leg in question.
Routing jig cramped in place Routing jig cramped in place
As it was cramped lightly in place, it was tapped with a maul so that it was coplanar (in other words, level) with the top of the leg. Once it had been correctly cramped in place and finally checked with a rule, the cramps were tightened (with soft blocks underneath the heads) so there was no possibility of the dreaded ‘slippage’ during the machining process. It certainly wouldn’t be the first time that a routing procedure had gone down the proverbial pan because I’d forgotten to tighten a screw.
False base on router False base on router
There’s still a difficulty though, as the router needs to span across to the top of the leg, so for complete safety I made a false 6mm plywood base (see pic ‘false base on router’) with a 25mm hole in the centre. Using an 8mm cutter, this gave me just enough room to see through the gap to make sure that I didn’t machine into the leg, which would have been a disaster of unmitigated proportions.
Sounds easy, but it’s not. Freehand routing like this is fraught with all sorts of difficulties, not least of which is that I couldn’t use dust extraction, so it was necessary to stop every few seconds and vacuum out the sawdust.
Corner routed out Corner routed out
As you can see from the pic ‘corner routed out’, I’ve freehand routed it and finished less than a millimetre from the pencil line as well as leaving the surface just the merest smidgeon above the rebate.
It’s impossible to use a router freehand like this with any degree of accuracy, so once the table is glued, the internal corners will be finished off with hand tools.
Leave a comment
