Metalworking Bandsaw Accessories | What To Buy Next For Your Metal Bandsaw
A metalworking bandsaw is one of the most efficient ways to achieve accurate, repeatable cuts in steel, aluminium, brass and other metals. Once you've invested in the machine itself, the right accessories can help improve cut quality, increase accuracy, extend blade life and make your workshop safer and more productive.
Whether you're setting up a new metalworking bandsaw or looking to get more from your current machine, here are some of the most useful accessories to consider adding next.
Replacement bandsaw blades
If there's one accessory every metalworking bandsaw owner should keep in stock, it's quality replacement blades.
Different materials and stock sizes often require different tooth pitches to achieve the best cut. Having a selection of blades available allows you to choose the most suitable option for the job, helping to improve cutting performance while reducing wear on both the blade and machine.
Signs it's time to replace your blade include:
- Slower cutting speeds
- Rough or uneven cuts
- Increased vibration
- Excessive noise during operation
Keeping spare blades on hand helps minimise downtime and ensures you're always ready for the next project.
Shop replacement bandsaw blades
Cutting oil and lubricants
Cutting metal generates significant heat, and excessive temperatures can shorten blade life and affect the quality of your cuts.
Using the correct cutting oil helps to:
- Reduce friction
- Extend blade life
- Improve cutting performance
- Produce a cleaner finish
- Prevent overheating
Whether you're cutting mild steel, stainless steel or non-ferrous metals, a suitable lubricant can make a noticeable difference to both performance and blade longevity.
Shop cutting oil and lubricants
Support stands and roller stands
Working with long sections of metal can be awkward without adequate support. Roller stands and material supports help keep stock level as it enters and exits the machine, reducing strain on both the operator and the saw. They also help improve cutting accuracy by preventing material from sagging during longer cuts.
These accessories are especially useful when processing:
- Box section
- Tube
- Bar stock
- Lengths of angle iron
- Structural steel sections
Machine vices and clamping accessories
Secure work-holding is essential for accurate, repeatable cuts. Upgrading or maintaining your bandsaw's vice system ensures material remains firmly in place throughout the cutting process. Additional clamps, replacement jaws and work-holding accessories can help improve accuracy while reducing the risk of blade binding. For anyone carrying out regular fabrication or production work, reliable clamping can significantly improve consistency.
Shop machine vices and clamping accessories
Measuring and marking tools
Accurate cuts start with accurate measurements. While many metalworking bandsaws include adjustable stops, adding quality measuring and marking tools helps ensure every cut is positioned correctly before the blade touches the material. Workshop essentials include:
- Steel rules
- Combination squares
- Vernier calipers
- Marking pencils and scribers
- Engineers' squares
These simple accessories can often have just as much impact on finished results as the machine itself.
Shop measuring and marking tools
Metalworking PPE
Metalworking creates sharp swarf, noise and airborne particles, making proper personal protective equipment a workshop essential.
Consider keeping the following close at hand:
- Safety glasses
- Face shields
- Hearing protection
- Protective clothing
- Workshop gloves suitable for material handling
The correct PPE helps keep you comfortable and protected throughout longer cutting sessions.
Shop metalworking PPE
Workshop extraction and clean-up solutions
A tidy workshop is a safer and more efficient workshop. Metal chips and swarf can quickly accumulate around machinery, making regular clean-up essential. Workshop vacuums, magnetic pick-up tools and cleaning accessories help maintain a safer working environment and keep machines operating at their best.
Shop workshop extraction and clean-up solutions
Get more from your metalworking bandsaw
A quality metalworking bandsaw is a valuable workshop investment, but the right accessories can help unlock its full potential. From replacement blades and cutting fluids to work-holding solutions and workshop safety equipment, these additions can improve accuracy, increase efficiency and help achieve consistently better results.
Whether you're cutting stock for fabrication projects, engineering applications or workshop jobs, equipping your bandsaw with the right accessories will help ensure it's always ready for the task ahead.
Final thoughts...
A metalworking bandsaw is a valuable addition to any workshop, but the right accessories can make a significant difference to its performance, accuracy and longevity. From selecting the correct replacement blades and cutting fluids to improving support, work-holding and workshop safety, these additions help you get the very best from your machine.
Whether you're cutting stock for fabrication, engineering projects or general workshop tasks, investing in the right accessories will help you achieve cleaner cuts, work more efficiently and keep your bandsaw performing reliably for years to come. With the right setup in place, you'll be ready to tackle a wide range of metalworking projects with confidence.
Discover more...
If you've enjoyed reading this guide, why not take a look at some of our woodturning blogs for inspiration, advice and project ideas?
Get in touch!
Get in touch via our social media platforms. Find us on Facebook or Instagram, where you'll discover project inspiration, new products and the latest woodworking and woodturning content from the Axminster team.
