Choosing the right Fuji Spray System
Choose the right Fuji Spray System for you
When it comes to professional HVLP spray systems, Fuji Spray offers a range of high-performance options tailored to different needs. Whether you're a mobile decorator, a workshop-based woodworker, or a high-volume finisher, choosing the right system can make all the difference in your workflow and results.
In this post, we’ll break down the key differences between Fuji Spray’s four standout series - D6™, Q PLATINUM™, MINI-MITE PLATINUM™ and SEMI-PRO2 - to help you decide which Fuji Spray System fits your needs best.
D6™ Series
Designed for high-end professionals who demand power, precision and quiet operation in workshops and on-site settings.
Fuji’s most advanced HVLP system to date, the D6™ spray system features a powerful 6-stage turbine that delivers up to 11.5 PSI, making it ideal for applying high-viscosity coatings such as latex and urethane with minimal thinning.
It includes digital controls that allow users to adjust pressure settings at the push of a button, ensuring consistent and repeatable results. Designed for professional environments, the unit boasts an ultra-quiet sealed housing that significantly reduces noise. A built-in remote control allows users to power the system on or off without needing to return to the base. It also includes a retractable gun holder and advanced dual filtration for added convenience and cleaner operation. Lightweight and ergonomically designed, the D6™ is easy to carry and manoeuvre, making it a practical choice for both workshop and on-site use.
Q PLATINUM™ Series
Quiet, powerful, and reliable - ideal for noise-sensitive environments.
The Q PLATINUM™ Series from Fuji is designed for professionals who need both power and quiet operation in their spray systems. It features 4- and 5-stage turbines, with the Q5 model being particularly popular for its balance of performance and control.
What sets this series apart is its patented noise reduction technology, which significantly lowers sound levels, up to 50% quieter than standard HVLP turbines, making it ideal for use in shared or residential spaces. The system also includes a master speed control that helps reduce overspray and bounce-back, improving finish quality and material efficiency. Compact and lightweight, the Q Series is easier to transport and set up than traditional compressor-based systems, making it a reliable choice for professionals who value both performance and a quieter work environment.
See the Q PLATINUM™ Series range
MINI-MITE PLATINUM™ Series
Rugged and portable - designed for on-the-go professionals who prioritise portability.
The MINI-MITE PLATINUM™ Series is Fuji’s most compact and portable HVLP spray system, designed for professionals who need mobility without compromising on performance.
It offers 3-, 4-, and 5-stage turbine options, delivering the same core power as the Q PLATINUM™ Series but without the added noise-reduction housing. This makes it louder in operation, but significantly lighter and easier to transport, making it ideal for decorators, woodworkers, and mobile finishers who work across different locations. Despite its smaller footprint, the MINI-MITE Series maintains high-quality spray performance, making it a practical choice for those who prioritise convenience and portability over ultra-quiet operation.
See the MINI-MITE PLATINUM™ Series range
SEMI PRO-2™ Series
Light-weight and robust, ideal for entry-level professionals and serious hobbyists.
The Semi‑PRO 2™ Series strikes the ideal balance between affordability, portability, and pro-level performance. Designed for furniture makers, cabinet refinishing, auto touch-ups, and home renovators, it delivers consistent, high-quality finishes on wood, metal, and more.
With a powerful 2-stage turbine, the Semi-PRO 2™ offers up to 5 PSI of atomising pressure - more than enough for lacquers, stains, enamels, and even some thinned latex paints. The included non-bleed M-Model spray gun (available in bottom or gravity feed) features adjustable fan control and a stainless-steel fluid path for durability and precision.
See the Semi-Pro2™ Series range
Which Fuji Spray System is right for you?
With four standout series - D6™, Q PLATINUM™, MINI-MITE PLATINUM™ and SEMI-PRO2™ - Fuji Spray offers a solution for every kind of professional. Whether you need maximum portability, ultra-quiet performance, or cutting-edge control, each system brings its own strengths to the table. The chart below breaks down the key differences to help you choose the best fit for your workflow.
Specification Chart
| Feature | D6™ | Q PLATINUM™ Series | MINI-MITE PLATINUM™ Series | SEMI PRO-2™ Series |
| Turbine Stages | 6-stage (11.5 psi) motor | 4-stage (9.0 psi) motor 5-stage (9.5 psi) motor | 3-stage (6.5 psi) motor 4-stage (9.0 psi) motor 5-stage (9.5 psi) motor | 2-stage (5 psi) motor |
| Noise Reduction | Yes (patented case design) | Yes (patented technology) | Yes (reduction cover) | - |
| Filtration | 2-stage with check filter light | 1-stage | 1-stage | 1-stage |
| Controls | Smart select control panel | Variable speed control dial (Q5 Platinum only) | - | - |
| Remote Control | Yes (easy pause remote) | - | - | - |
| Hose | 30ft hose with quick-connect and air control valve | 25ft Hi-Flex hose with quick-connect and air control valve | 25ft Hi-Flex hose with quick-connect and air control valve | 25ft Hi-Flex hose with quick-connect and air control valve |
| Portability | High | Moderate | Very High | Very High |
| Applications | High-end furniture, cabinetry, and industrial finishing - ideal for both workshop and on-site use. | Medium to heavy painting projects, including cabinets, furniture and trim - ideal for noise-sensitive environments. | Fine-finishing projects like cabinetry, furniture, and woodworking - ideal for mobile and workshop use. | Small to medium projects, including cabinet refinishing, auto touch-ups and home renovations |
| Coatings Compatibility | Ideal for a variety of finishes: stain, shellac, polyurethane, lacquer, oil and water-based paints and primers | Ideal for a variety of finishes: stain, shellac, polyurethane, lacquer, oil and water-based paints and primers | Ideal for high viscosity industrial finishes & coatings: catalysed lacquers, primers, varnishes, urethane, enamels, polyurethane, paints, and 2k acrylic topcoats | Ideal for a variety of finishes, stain, shellac, polyurethane and lacquer |
| Ideal For | High-end professional use | Professional quiet, shared spaces | On-the-go professionals | Entry-level professionals |
Choosing the right system comes down to your environment, your materials, and the level of control you need. With any of these options, you're investing in performance, reliability, and the quality Fuji is known for.
Now, just choose the right gun for precision in every spray
Fuji offer a versatile range of spray guns compatible with their systems, giving users the choice between bottom-feed, gravity-feed, and side-feed options to suit any project or spraying style.
7001 & 7002G M-Model Spray Guns
The M-Model guns are only compatible with the Semi-Pro2 but share the same high build and material quality as the Fuji T and G professional spray guns. The 7001 is a bottom-feed (suction) gun with a 1,000cc cup, and the 7002G is a gravity feed with a 400cc cup. Being lighter and more manoeuvrable, they are a good choice for smaller projects or cabinet interiors.
T70 T-Model Spray Gun
The Fuji T70 is a non-bleed HVLP suction spray gun with a 950cc pressurised cup, ideal for large-scale projects like cabinetry and automotive refinishing. It offers versatile spray pattern control and the ability to spray in any direction.
T75G T-Model Spray Gun
The T75G is a gravity-fed alternative featuring a 600cc top-mounted cup, designed for professional-grade finishes. It shares the same ergonomic design and fan pattern control as the T70, making it a reliable choice for precision work.
G-Xpc Model Spray Gun
The G-Xpc features a 400cc side-mounted rotating cup, perfect for upward spraying and tight-angle applications. Like the T70 and T75G, it includes ergonomic handling and adjustable fan pattern control for maximum versatility.
Fuji spray guns are also available to purchase separately:
Final thoughts
Whether in furniture finishing, automotive detailing or decorative painting, Fuji’s advanced turbine technology ensures smooth, consistent, and high-quality finishes - every time. From the powerhouse D6 to the portable Mini-Mite, and from the versatile T70 to the precision-focused G-Xpc, Fuji delivers performance, control, and finish quality that consistently exceed expectations.
Fuji Spray 7001 M-Model Suction Spray Gun
Fuji Spray 7002G M-Model Gravity Spray Gun
Fuji Spray T70 T-Model Suction Spray Gun
Fuji Spray T75G T-Model Gravity Spray Gun
Fuji Spray G-Xpc Gravity Spray Gun
