Fuji Spray
A close-up of a person holding a blue spray gun in front of a wooden fence, with a large white banner across the center featuring the blue and gray FUJI SPRAY logo.
Precision finishing, professional results
For over 35 years, Fuji Spray has set the standard in high-performance spray systems. Designed and engineered in Canada, their HVLP (High Volume Low Pressure) technology delivers unparalleled control, efficiency and finish quality across a wide range of materials.
Whether you're a seasoned professional or a passionate DIYer, Fuji Spray's systems empower you to achieve smooth, consistent results with minimal overspray and maximum precision. From furniture and cabinetry to automotive and industrial applications, Fuji Spray is the trusted choice for flawless finishes.
Own the system trusted by finishers worldwide and elevate your work with Fuji Spray.
Buy with confidence
Fuji Spray products are backed by a 2-Year manufacturer's warranty. No registration is required, but proof of purchase should be retained for any warranty claim. For full terms and warranty support visit the Fuji website.
Visit Fuji Spray online
Fuji Spray Systems demystified
Explore our guides on choosing, using and caring for your spray system
A close-up of a hand holding a silver and blue spray gun, spraying a fine mist of liquid against a dark grey background.
FINISHING
Choosing the right System
A hand holding a spray gun with a metal paint can, spraying a light natural wood spindle-back chair in a workshop setting with a blue pegboard background.
TOP TIPS
Fuji Spray | HVLP Spraying Tips
A person's hands holding and pointing to a silver metal spray gun attachment with blue and yellow accents, set against a dark background with a workbench containing a water bottle, a small bottle, and other tools.
FINISHING
How To Clean Your HVLP Spray Gun
A close-up of a hand holding a silver and blue spray gun and applying paint to the body of a blue acoustic guitar against a light wood background.
FINISHING
Waterborne Finishes
Fuji Spray HVLP Paint Sprayers
Fuji Spray is a leading name in HVLP (High Volume Low Pressure) spray systems, renowned for delivering professional-quality finishes with precision, control and efficiency. Designed for woodworkers, decorators, automotive refinishers and fine finishers, Fuji Spray systems offer exceptional atomisation and minimal overspray, resulting in smooth, even coatings with less waste. Whether you're applying lacquer, varnish, paint or stain, Fuji’s turbine-driven HVLP systems provide consistent performance and a flawless finish on every project. Built in North America with robust components and ergonomic designs, Fuji Spray equipment is engineered for durability and ease of use. Explore our range of Fuji Spray systems and accessories to achieve a professional-grade finish with every application.
