Woodworking Wisdom
How To Use A Kitchen Worktop Jig
Position jig across the end of the worktop
Router, guide bushes, cutters and clamps
Ear defenders and dust mask
Creating A 90° Left Hand Joint
Jig positioned and clamped
Step 1
Position and clamp the jig to cut the female section of the joint.
Step 2
A worktop with a melamine surface and thick chipboard core present a challenge to any router cutter so it’s best to proceed with caution.
Take a series of small cuts until the waste piece falls away.
It’s also advisable to fit the dust extraction fitting to the router but this may obstruct the view of the cutter. If the extraction outlet isn’t fitted, use the shop vacuum after each cut to clear away the sawdust.
Make a series of small cuts until the waste piece falls away
Clear away the sawdust with extraction device
Step 3
To cut the recesses for the worktop connector bolts, position two of the pins in the location (arrowed) and take several small cuts to finish at a total depth of 20mm.
Position two of the pins
Take several small cuts to finish at a total depth of 20mm
Recesses for the worktop connector bolts
Cut the worktop
Step 4
Cutting kitchen worktop is very easy with a circular saw and ‘shop made ‘T’ square, make sure the worktop is ‘underside up’ so that the leading teeth of the saw blade cut through the melamine surface on the ‘up’ stroke.
Step 5
To cut the other half of the joint, position the jig across the end of the worktop and locate it with two pins in the M90 holes.
Cut the worktop
Cut other half of the joint
Step 6
Turning both pieces over, use a pencil to mark the position (arrowed) of the remaining connector bolt recesses. Using a narrow piece of worktop, it’s only possible to locate two of the pins (arrowed) but check the jig for the correct alignment by using a square across one edge.
Mark the remaining connector bolt recesses
Check for correct alignment
Step 7
Machine the recesses and then cut the connector bolts to the correct length and assemble the joint
As this was for demonstration purposes only, no glue was used. However for a kitchen installation use a waterproof polyurethane glue before tightening the connector bolts.
Connector bolts are cut to the correct length and joint assembled
Worktop joint
Creating A Right Hand Variable Joint
When cutting a variable joint, it’s essential to study the manual to follow the correct procedure and ensure the worktop is the right way round. Cutting the female section of the joint is identical to the previous example, except that now you need to machine the worktop ‘face up’. Machine the connector recesses identically as in the previous example.
Step 1
Use a protractor to mark out the offset angle (5°) on the female section of the joint. This is the maximum setting of the Angle Adjustment Plate.
Mark out the offset angle (5°)
Step 2
As the pencil line is now at 85° to the edge, the circular saw and ‘T’ square can no longer be used. In which case it’s easy enough to cut the end true and to the correct angle using the jig. Using a 30mm guide bush and 12mm cutter, the offset is 9mm (30-12 / 2 = 9).
Step 3
Prepare a 9mm strip of timber and then use this to line up the jig’s slot parallel to the pencil line. Next clamp in place and make the cut.
9mm strip of timber used to line up the jig’s slot parallel to the pencil line
Clamp in place and make the cut
Step 4
To cut the other half of the variable joint, bolt the Adjustment Angle Plate onto the jig and set to the offset angle of 5°. It’s vital to double check the cut will be in the correct place by visually examining the joint before cutting. Once satisfied, turn the worktop and jig over, clamp to the workbench and make the cut.
Bolt Adjustment Angle Plate onto the jig and set to the offset angle of 5°
Clamp jig and worktop to workbench
Cut other half of joint
Step 5
Complete the recesses for the connector bolts, and then fit and tighten. You can then turn the worktop over. The large 300mm workshop square shown in the image emphasises the variable angle of the joint.
Fit and tighten connector bolts
Workshop square emphasising the variable angle of the joint
Blade and bit cleaner
Cutting through chipboard and melamine can present a severe challenge for a router bit. However the long shank ½” cutter came through the experience with flying colours. After soaking for a few moments in Blade & Bit Cleaner, the cutter is still very sharp and capable of a lot more work.
Conclusion
Post formed kitchen worktops are difficult beasts to handle at the best of times. It’s well worth proceeding with some care when making joints in them. That said, the UJK Technology Kitchen Worktop Jig will make a variety of faultless joints with the minimum effort.
Leave a comment
