Why Does My Bandsaw Blade Wander?
Why does a bandsaw wander?
A bandsaw typically wanders because of one or more of the following:
- A dull or damaged bandsaw blade
- The wrong blade width or tooth pattern for the job
- Incorrect blade tension
- Poor blade tracking
- Misaligned blade guides
- Fence setup errors during resawing
- Insufficient blade strength for the material being cut
In most cases, replacing the blade and checking the machine setup will solve the issue.
Causes, fixes and how to achieve straighter cuts
1. Your bandsaw blade is dull
The most common cause of bandsaw wander is simply a worn-out blade.
As bandsaw teeth become dull, they struggle to remove material efficiently. Instead of cutting cleanly through timber, the blade begins to follow the path of least resistance, causing it to drift left or right.
Signs of a dull bandsaw blade:
- Increased feed pressure needed
- Burn marks on timber
- Rough cut surfaces
- Blade drifting off the cut line
- Excessive vibration
If your blade has been heavily used or accidentally damaged by knots, nails or contaminants in the material, replacement is often the quickest solution.
Recommended solution
Here at Axminster Tools, we stock a huge range of UK-made Axcaliber bandsaw blades designed to deliver straighter cuts and improved finishes across a variety of woodworking applications. The range includes Ground Tooth and Freshcut blades for different cutting requirements.
2. You're using the wrong blade
Not every bandsaw blade is designed for every job. Using a narrow blade for deep resawing, for example, can result in significant blade deflection and wandering.
Blade selection guidelines
| Application | Recommended Blade |
| Tight curves | Narrow blade |
| General woodworking | Medium-width blade |
| Resawing hardwoods | Wider blade |
| Thick stock cutting | Lower TPI blade |
| Thin materials | Higher TPI blade |
Choosing the correct blade width, tooth pitch and blade length dramatically improves cutting accuracy.
Find the right blade fast
The Axminster Bandsaw Blade Finder allows you to enter your bandsaw blade Tpi, blade type, blade length and width details, and provides you with compatible Axcaliber blade options.
3. Incorrect blade tension
A bandsaw blade must be tensioned correctly to track accurately. Too little tension allows the blade to flex under cutting pressure, leading to drift. Too much tension can increase wear on the blade, bearings and machine components.
Common symptoms of low tension
- Blade twisting during cuts
- Difficulty cutting straight lines
- Uneven cut quality
Always refer to your machine's manual and blade manufacturer's recommendations when setting tension.
4. Poor blade tracking
Blade tracking determines where the blade sits on the wheels. If a blade is not tracking correctly, it can pull sideways during cuts and create wander even when the blade is sharp.
Check the following:
- Blade centred correctly on wheels
- Upper wheel tracking adjustment
- Wheel alignment
- Tyre condition
Before making fine adjustments to fences or guides, always ensure tracking is correct.
5. Blade guides need adjustment
Bandsaw guides play a crucial role in controlling blade movement.
If guides sit too far away from the blade or have become worn, they won't provide adequate support during cutting.
Check your guide setup
- Side guides positioned close to the blade
- Rear support bearing correctly adjusted
- Upper guide assembly lowered close to the workpiece
- Bearings rotating freely
Even small guide adjustments can significantly improve cut accuracy.
Upgrade your guides
The Axminster Bandsaw Blade Guide System Upgrade replaces traditional rubbing blocks with ball-bearing supports. This improved support system helps reduce blade vibration and can contribute to cleaner, more accurate cuts.
For compatible machines, Axminster Tools also offers dedicated blade guide sets that can help improve blade stability and performance.
6. Your fence may be misaligned
If your blade naturally drifts slightly but your fence is set perfectly parallel to the mitre slot, resawing cuts can still veer off course. Many woodworkers mistakenly blame the blade when the fence setup is actually at fault.
When resawing:
- Test-cut a straight line freehand
- Observe the blade's natural tracking angle
- Adjust the fence to compensate if necessary
A well-adjusted fence can transform resawing performance.
Useful accessories
At Axminster Tools, we offer several bandsaw accessories designed to improve cut control and accuracy, including:
These accessories can make repeatable, accurate cuts easier to achieve.
7. Blade quality makes a difference
Not all bandsaw blades are manufactured to the same standard. Premium blades typically offer:
- More consistent welds
- Better tooth geometry
- Improved tracking
- Longer lifespan
- Cleaner finishes
If you've checked your setup and still experience wander, upgrading to a higher-quality blade is often worthwhile.
Axcaliber bandsaw blades are manufactured for woodworking applications and are available in a wide range of lengths, widths and tooth configurations suitable for hobbyists and professional workshops alike.
Frequently Asked Questions
Why does my bandsaw blade drift to one side?
The most common reasons are a dull blade, incorrect blade tension, guide misalignment or using the wrong blade for the task.
Will a new blade stop bandsaw wander?
In many cases, yes. A fresh, correctly specified blade is often the quickest fix for wandering cuts.
What blade is best for resawing?
A wider blade with fewer teeth per inch generally provides greater stability and straighter cuts when resawing thick timber.
How do I find the correct replacement blade?
The Axminster Bandsaw Blade Finder allows you to input your blade requirements to identify compatible blades and suitable replacement options.
Got a question or need advice?
Call our Customer Support Team on 03332 406406.
Final thoughts...
When a bandsaw starts to wander, it's usually a symptom rather than the problem itself. A dull blade, poor tension, incorrect blade selection or worn guide system are often the real causes.
Start with the basics:
- Inspect the blade
- Check blade tension
- Verify tracking
- Adjust the guides
- Confirm fence alignment
If you're ready to improve performance, explore our range of Axcaliber Bandsaw Blades. Why not use the Axminster Bandsaw Blade Finder to input your blade requirements and find suitable blades for your bandsaw, and consider upgrades such as the Axminster Bandsaw Blade Guide System Upgrade and Rip Fence Upgrade to maximise accuracy and control?
With the right setup, your bandsaw should cut straight, smooth and accurately every time.
Discover more...
We hope you've enjoyed learning about bandsaw blades. When you get a chance, why not take a look at some of our blogs?
Axminster BS11 Bandsaw Blade Guide Set
Axminster HBS350N Bandsaw Blade Guide Set
Axminster Rip Fence Upgrade
Axminster Small Rip Fence Upgrade
UJK Bandsaw Buddy
UJK Precision Mitre Gauge Fence & Flip Stop
