bott uno3 Van Racking
- Efficient van storage offering quality at an affordable price
- Crash tested to comply with ECE R17 standards
- Choose the module to suit your vehicle from the technical data sheet in the information downloads below
- Various sized modules available to suit your vehicle
- Made from galvanised and powder-coated steels
- Mobile working solutions to improve organisation
- Additional extras available to enhance performance
- Easy to follow instructions provided for a quick and easy assembly
- Self-assembly and installation
- Suitable for varying trades
- Made in Britain
- 3-year manufacturer warranty
- Show More
The bott uno3, a self-fitting van racking system ensuring a safe, reliable, well organised workspace; helping to create a great first impression with customers. The system is a simple, self-fit solution, high-quality van racking setup which offers an alternative to traditional wood-racking systems. It's functionality and durability are second to none, all at an affordable price. Van storage solutions couldn't be made easier with the bott uno3.
Produced from galvanised and powder-coated steels, the standard modules are protected from general wear and tear to ensure long-lasting storage and prevent your tools from coming to harm's way. The bott uno3 provides the perfect storage systems for systainers, including Festool and UJK. The system offers a range of other useful features including mobile working solutions; integrated shelves and bottBoxes to elevate your tool organisation, whatever trade you're in.
Made to order in the UK, the racking is available in various sized modules including single standard and dual standard modules, depending on the make and model of your vehicle. Single standard modules are available in 4 widths ranging from 814-1,486mm, 1 depth (360mm) and 2 heights; 1,000 and 1,200mm. Dual standard modules are available in 5 widths ranging from 1,822-2,718mm, 1 depth (360mm) and 2 heights; 1,000 and 1,200 mm.
Additionally, the system includes robust 1.4mm end frames, designed to allow for flexible incorporation of an extensive range of mounted tool holders and accessories, to help with organisation. Finished in epoxy powder-coat paint (RAL7016 Anthracite Grey).
A floor with a minimum of 8mm depth will be required to be able to fit the racking to the vehicle. We do not recommend drilling through the van floor itself.
Having safety at the forefront of the system, the bott uno3 has been crash tested to ECE R17 standards. Moving parts such as tool cases and bottBoxes are kept firmly in place during transit and optional extras such as anti-slip mats are available to help prevent any other movement.
Please note: the racks are supplied flat packed and self-assembly is required. Easy-follow instructions are provided, to allow for assembly to be quick and efficient.
The bott uno3 is a strong, high-quality storage answer and exceptional choice for your van storage needs. A 3-year manufacturer warranty is also available.
To choose your van racking modules, use the Technical Data Sheet PDF attached in the information downloads section below to view which modules are compatible with your vehicle. Select the correct order code and choose from the drop down menu to order.
