Your go-to choice for traditional wood or metal work
Whether you’re a DIYer or beginner, the Perform PD8D offers reliable, user-friendly drilling with features like adjustable speeds and a tilting table, perfect for a variety of home workshop projects.
A yellow PERFORM brand drill press mounted on a wooden workbench in a workshop, with a person in a blue shirt adjusting the machine's lever.
Strong and sturdy
The base, table and head are made of strong cast iron, giving this drill stability and strength.
Close-up of a person's hands adjusting a drill bit on a yellow and black drill press with a red guard and clear safety shield.
Chuck capacity
The drill features a 1.5-13mm keyed chuck with a self-ejecting chuck key for secure bit holding and easy bit changes. The 50mm chuck travel enables deeper drilling for tasks that require it.
A close-up of a person operating a yellow and black drill press with a red chuck and blue base in a workshop setting.
Depth stop
The easy-to-use depth stop allows for simple adjustment, enabling precise control over drilling depth for consistent results.
A yellow and black drill press with a clear dust collector cup, set against a workshop background with tools and a hanging apron.
Induction motor
A quiet running 200W induction motor ensures for smooth, consistent operation reducing noise and vibrations for a more comfortable drilling experience.
A person's hands holding a bright yellow  drill press base with black pulleys and belts, set against a grey cinderblock wall background.
Easy speed adjustment
Offering 5 adjustable speeds ranging from 550-2500rpm, the PD8D is ideal for drilling a variety of materials. Easily adjust the speed using the belt system.
Tilting table
The 166 x 160mm table tilts from 45̊ – 0̊ - 45̊, accommodating angled holes with ease.
An extra helping hand for your PD8D
A drill vice gives you extra control when using a bench drill. It holds your workpiece firmly in place, so you can drill more accurately and safely - especially when working with smaller pieces. Simply attach it to the drill press table and adjust to fit your timber.
Shop now
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The Perform PD8D Bench Drill makes a perfect first drill for DIY and home workshop tasks.
Offering precision for a range of light-duty drilling tasks, it features a 1.5-13mm keyed chuck with a self-ejecting chuck key for secure bit holding and easy bit changes. The 50mm chuck travel enables deeper drilling for tasks that require it. Its strong cast iron construction of the base, table and head delivers stability and durability.
Powered by a 200W induction motor, the drill offers smooth operation across 5 easily adjustable speeds ranging from 550-2,500 rpm which makes it ideal for drilling into various materials. The belt cover has a safety switch to ensure safe speed changing. The easy to use depth stop allows for consistent, repeatable drilling depths.
The 166 x 160mm table tilts 0-45 in both directions, accommodating angled holes with ease. Table height is adjusted by sliding the table assembly up or down the column. For taller work the table can be swivelled away to allow the base to be used as a work support. A front mounted NVR switch and the adjustable chuck guard add to the convenience of use. The belt cover has a safety switch to ensure safe speed changing.
This drill is excellent for beginners and a useful machine to have in your home workshop space.
Please note: The PD8D is not suitable for a morticing attachment.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 430 x 230 x 590 mm
Power 200 W
Rating Occasional Use
Table Size 166 x 160 mm
Table Tilt 45 - 0 - 45
Chuck Capacity 1.5 mm to 13 mm
Chuck Type keyed
Throat Depth 100 mm
Plug Fitted UK 3 pin plug
Web Attribute Set Drilling Machines
EAN Barcode 5052511142149
