A powerful, capable machine
The AP3600B Bandsaw will add serious ability to your workshop and no doubt become a workhorse among your machinery.
Buy with confidence
Cutting capacity
Huge cutting capacity
With a generous 360mm depth and 420mm width of cut, you can handle impressive timber sizes.
Large cast iron table
The table is 485mm x 560mm cast iron with double trunnion table support. This offers maximum support for heavier pieces.
Powerful 2.5kW motor
The AP3600B has the power to match the capacity, meaning it can cut 360mm material with ease.
T-style Hi/Lo Rip Fence
T-style Hi/Lo rip fence
Rigid, easy glide rip fence with two height options for accurate heavy duty ripping and close to the blade work.
Cast iron blade wheels
Achieve cleaner, smoother cuts thanks to the fully balanced blade wheels which reduce vibration and maintain blade speed.
Superior blade guides
Independent adjustable blade guide system for quick and easy set up.
Heavy duty handwheels
These durable metal handwheels will provide smooth adjustment for years to come.
Rack & pinion upper guide adjustment
Easily adjust the upper blade guide with the rack and pinion rise and fall. There is also a tension release lever for straightforward blade changes.
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The AP3600B is a modern and capable bandsaw, offering robust build quality alongside impressive cutting power.
With a generous 360 mm depth and 420 mm width of cut possible, it also features a large 485 mm x 560 mm cast iron table. The table is engineered with a double trunnion table support, making it ideal for supporting large pieces of timber with ease. The powerful 2.5kW motor means you can easily handle big cuts, as required in a demanding workshop.
The bandsaw is supported by a solid steel tubular frame which limits vibration. It comes supplied with a rigid T-style, easy glide Hi / Lo rip fence for highly accurate cuts. The cast iron blade wheels are fully balanced, reducing vibration further as well as reducing any fatigue from use.
You can rest assured that this machine meets all safety requirements: it features a key switch for extra safety when away from the machine, as well as an emergency stop switch. Dual dust extraction ports provide efficient methods of dust extraction to keep your workshop clean and dust free.
Set up is a breeze; premium blade guides and a quick release blade tension lever make changing or adjusting your blades quick and easy. With levelling feet, you can get your bandsaw perfectly aligned in the workshop. Heavy duty metal handwheels mean your machine will remain in service longer.
Supplied with a 3/4 x 3 TPI blade.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Please note, if you require an EU plug, please ensure you purchase 113776
Dust Extraction Outlet 100 mm & 63 mm
Max Width of Cut with Fence 335 mm
Overall L x W x H 970 mm x 960 mm x 1,915 mm
Power 2.5 kW
Rating Frequent Use
T Slot Size 19 mm
Table Height 895 mm
Table Size 485 mm x 560 mm
Table Tilt 0 - 45
Min Extraction Airflow Required 1,200 m³/hr
Sound Power Level LwA [Uncertainty K] 76.2 dB(A)
Sound Pressure Level LpA [Uncertainty K] 72.3 dB(A)
Plug Fitted UK 16A Plug
Web Attribute Set Bandsaws
EAN Barcode 5052511132379
  • UK Mainland - £70
