1.5mm to 15mm thick soft wood, laminated boards, plywood especially suited to tight curved corners.
Jigsaw Blade Length 51 mm
Max Cutting Depth 15 mm
Model T101AO
Blade Type HCS, Ground and Taper Ground
Jigsaw Blade Type Tight Curves
Pack Quantity 5
Tooth Pitch \ tpi 1.40 mm \ 18 tpi
Blade Type HCS
Pack Quantity 5
Model T101AO (Pkt 5)
Quantity 5
Jigsaw Cutting Depth [Cat] 1.5-15 mm
EAN Barcode 3165140006798
