Perform
Perform PD50E 50L Wood Dust Collector 230V
SKU: 113367
€98,00
  • 63mm inlet, suits many common machines
  • 2 stage filtration, removes 99% wood dust particles > 1 micron
  • 50L drum capacity
  • Airflow: measured in our workshop 440m³/hr @ 63mm
The PD50E is a practical solution for dust and chip extraction in small home workshops, offering a dedicated alternative to using a domestic vacuum cleaner. Compact in design, the unit features a 50-litre drum with a 420mm diameter and stands 730mm tall, making it space-efficient and easy to position within limited workshop areas.
Equipped with a two-stage filtration system-comprising a cartridge filter and an outer paper filter-the PD50E provides effective fine particle filtration, capturing 99% of particles greater than 1 micron. The extractor includes a 63mm inlet for connecting to compatible workshop tools and accessories.
The power head features an integrated carry handle for portability and is secured to the drum with a robust metal quick-release strap. Airflow performance: measured in our workshop is 440m³/hr @ 63mm.
Supplied with a spare set of carbon brushes for easy maintenance.
N.B. Extraction hose not included.
Please note, if you require an EU plug, please ensure you purchase 113504
Airflow 440 m³/hr @ 63 mm (28-40 m/s)
Filter Performance 99% 1 micron
Inlet 63 mm
Overall L x W x H 420mm x 420mm x 670mm
Power 1.2 kW
Rating Occasional Use
Sound Pressure Level LpA [Uncertainty K] 85 dB(A) [1.5 dB]
Plug Fitted UK 3 pin plug
Web Attribute Set Fine Dust Extractors
EAN Barcode 5052511142118
