5 - 15mm, wood laminates, clean precise cutting on both sides of the laminate.
Bosch
Bosch T101BIF Jigsaw Blades Special Laminate (Pkt 5)
| Jigsaw Blade Length | 82 mm |
| Max Cutting Depth | 15 mm |
| Model | T101BIF |
| Blade Type | Bi-metal, Ground and Taper Ground |
| Jigsaw Blade Type | Clean Cuts |
| Pack Quantity | 5 |
| Tooth Pitch \ tpi | 1.70 mm \ 15 tpi |
| Model | T101BIF (Pkt 5) |
| Quantity | 5 |
| Jigsaw Cutting Depth [Cat] | 1.5-15 mm |
| EAN Barcode | 3165140393416 |
