To cut a thickness of 1.5mm - 4mm stainless plate as well as other tough materials. The bi-metal laser welded combination of HSC and HSS gives longlife with a high break resistance, the HSS tooth has 8% cobalt making it very robust and more heat resistant than standard blades, the special milled and wavy set on the tooth strip for optimum cutting.
Jigsaw Blade Length 57 mm
Max Cutting Depth 15 mm
Model T118EFS
Blade Type Bi-metal, Milled and Wavy Set
Pack Quantity 5
Tooth Pitch \ tpi 1.40 mm \ 18 tpi
Quantity 5
EAN Barcode 3165140451857
