Clean accurate and tear free on both sides of the hardwood and laminate material. Two rows of teeth arranged at different angles, a razor sharp scalpel tooth will cut the wood fibres on the reverse whilst a precision ground pointed tooth separates the wood fibres on the top surface and give super clean cuts. BIM longlife blades suitable for hard wood and high quality laminate boards.
Bosch
Bosch T308BF Jigsaw Blades Tear Free Hardwood (Pkt 5)
| Jigsaw Blade Length | 91 mm |
| Max Cutting Depth | 20 mm |
| Model | T300BF |
| Blade Type | Bi-metal, Ground |
| Jigsaw Blade Type | Clean Cuts |
| Pack Quantity | 5 |
| Tooth Pitch \ tpi | 2.20 mm \ 11.5 tpi |
| Model | T308BF (Pkt 5) |
| Quantity | 5 |
| Jigsaw Cutting Depth [Cat] | 5-50 mm |
| EAN Barcode | 3165140470322 |
