Powerful, precise performance for busy workshops
Ideal for tasks requiring extra precision and care, the AP25FDMS Variable Speed Floor Pillar Drill is designed for simple yet effective operation, with single lever speed adjustment. It sits just below the flagship model in our Professional range.
Drilling using AP25FDMS
Buy with confidence
Powerful motor with variable speed
Powered by a 1.1 kW variable speed motor, it delivers smooth, precise drilling across two belt speed settings: 180 - 600rpm and 580 - 2,000rpm. The result is greater efficiency, longer tool life, and confident performance on demanding jobs while maintaining accuracy and control.
Full 150mm spindle travel
Deeper drilling in a single pass is made easy thanks to the 150mm spindle travel and 430mm swing. This ensures the drill is compatible with various sized materials.
Depth stop
Depth stop
The depth stop allows for easy adjustment, enabling precise control over drilling depth for fast, consistent results.
Heavy duty cast iron construction
The cast iron head, table, and base are supported by an 80mm column, creating a rigid platform under load. Combined with the heavy duty construction, this ensures excellent stability and minimal vibration.
Rack and pinion table adjustment and table tilt
The rack and pinion mechanism provides quick and easy table adjustments, making it simple to position your workpiece accurately. Plus, the table also tilts 45° each way to allow angled drilling.
Cartridge filter with manual dual paddle cleaning
LED work light
The integrated LED work light clearly illuminates the cutting area for improved visibility during longer or more precise tasks.
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The Axminster Professional AP25FDMS Variable Floor Pillar Drill is a robust, high performance solution designed for workshops that demand strength, precision, and versatility. It's ideal for small to medium sized professional workshops or serious home workshops requiring heavier duty capability.
Powered by a 1.1 kW motor with variable speed drive, it delivers smooth, precise drilling across two belt speed settings: 180 - 600rpm and 580 - 2,000rpm. Speed can be easily fine tuned to suit different materials and cutter sizes for greater efficiency, improved tool life, and the confidence to take on larger, more demanding jobs, all while maintaining accuracy and control.
Built for stability, the machine features a heavy duty cast iron head, table, and base, supported by an 80 mm column to create a rigid platform under load. The large cast iron table, with smooth rack and pinion height adjustment, provides excellent support and easy positioning for both small and large workpieces. The table also tilts to 45 each way to easily allow angled drilling.
With 150 mm of spindle travel and a generous 430 mm swing, it offers significant capacity for various sized materials, allowing deeper drilling in a single pass. An adjustable depth stop ensures fast, accurate, and repeatable results, while the integrated LED work light clearly illuminates the cutting area for improved visibility during longer or more precise tasks.
Ideal for small to medium professional workshops, or serious home users, the AP25FDMS Variable Speed Floor Pillar Drill is an excellent step up from lower grade models and delivers the performance, reliability, and ease of use needed for frequent, demanding work. It offers professional capability without moving to industrial grade prices.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 735 x 325 x 1,830 mm
Power 1.1 kW
Rating Frequent Use
Table Size 356 x 356 mm
Table Tilt 45 - 0 - 45
Chuck Capacity 20 mm
Chuck Type keyed
Throat Depth 215 mm
Plug Fitted UK 3 pin plug
Web Attribute Set Drilling Machines
EAN Barcode 5052511142446
  • UK Mainland - £70
