The SawStop Folding Outfeed Table makes handling large workpieces easier and safer. Constructed from durable powder-coated steel, with a stamped steel support plate and robust support legs, the table matches the full width of the cast iron table and wings and is strong enough to support up to 113 kg with ease.
The table can be configured to suit your setup, even if a wing has been removed to accommodate a sliding table. Three integrated roller bars ensure smooth timber movement and maximum glide during cutting.
Designed with space efficiency in mind, the outfeed table folds down effortlessly by lifting the support legs, making storage simple and helping to maximise workshop space.
Compatible with all SawStop Cast Iron Table Saw Mobile Bases.
Overall L x W x H 1.124 mm x 816 mm
Web Attribute Set Saw Bench Accessories
EAN Barcode 857555005963
