Offered as Right or Left handed Flip Stops for the TSO Parallel Guide System.
Material stops are often overlooked, but they set the exact dimension of every rip and that makes them one of the most important parts of the system. The Flip Stop Pro takes that role seriously, giving you zero-deflection strength, zero-parallax accuracy, and a redesigned calibration system that sets once and holds - making it easier than ever to dial in precision.
Suitable for TSO Parallel Guides generation 1 and 2 as they are backward-compatible with the original Parallel Guide System, making them an easy upgrade if you’re still using the first version.
Supplied in singles Right or Left handed
