Thicknessing made easy
The PD318BT Benchtop Thicknesser takes the hassle out of achieving precise timber thickness. With its generous capacity, powerful motor, and quality blades, it’s the ideal choice for DIY enthusiasts and home workshops alike.
A light natural wood workbench with an open lower shelf in a workshop setting, holding a yellow thicknesser. A red tool chest, a yellow shop vacuum, and a grey cinderblock wall are visible in the background.
Small and compact
The PD318BT Benchtop Thicknesser is ideal for smaller workspaces thanks to its compact size.
A yellow and black Perform  wood thickness planer in use on a workbench, with a person's hands guiding a piece of wood through the machine in a workshop setting.
Impressive capacities
With a maximum thicknessing width of 318mm and a height capacity of 153mm, the thicknesser can handle most tasks with ease.
A close-up of a person's hand adjusting a fold out table  on a yellow and black Perform thicknesser on a light wood bench.
Fold down extension tables
Equipped with sturdy fold down extension tables, the PD318BT easily supports longer boards ensuring steady planing. Built in rollers let you feed heavier workpieces effortlessly.
Close-up of a dark grey and yellow machine with a black label reading PERFORM PD318BT in yellow, mounted next to a bright yellow vertical frame and a measuring scale.
Easy to read scale
The easy-to-read scale allows you to quickly and accurately set your desired timber thickness, meaning adjustments are simple and efficient.
A man wearing a red and navy plaid shirt and red ear protection operates a yellow and black Perform wood thickness planer on a light wood board in a workshop setting.
Powerful motor
The high powered 1.8kW motor maintains blade speed for a consistent cut and quick stock removal.
A close-up of a person's tattooed arm guiding a light-colored wood sheet through a thicknesser with a clear dust collector hose connected.
Efficient cuts per minute
With 18,000 cuts per minute, you'll achieve a smooth, clean finish on every project in no time.
Two long, narrow metal blades with printed markings, resting diagonally on a light wood board inside a workshop setting.
High speed steel blades
The two high speed steel blades help to achieve excellent, smooth results and can be re-sharpened so you can use repeatedly.
A close-up of a person's hand connecting a clear corrugated flexible hose to a black cylindrical port on a dark grey and yellow machine.
Safeguard your health
Connect your benchtop thicknesser to a suitable vacuum extractor via the 50mm dust port.
If you're new to woodworking and looking for your first thicknesser, the Perform PD318BT is a fantastic place to start. It's compact, easy to use, and simple to store thanks to its fold-up tables. These tables also help to support longer pieces of wood, making your work easier and more stable.
This machine has a strong 1,800W motor that can remove up to 2.5mm of material in one pass, helping you shape your wood quickly and efficiently. It uses two high-speed steel (HSS) blades that can be re-sharpened, delivering up to 18,000 cuts per minute. Combined with a feed speed of 7 m/min, this gives your wood a smooth, clean finish. An easy-to-read scale makes adjusting the machine simple, even if you’re just starting out.
You can work with timber up to 153mm thick and 318mm wide, which is great for a variety of projects. The fold-down table extensions at the front and back, along with end rollers, give extra support when working with longer boards.
To help keep your workspace clean, there's a 50mm dust extraction outlet that you can connect to a vacuum extractor. For safety, the motor includes overload protection and a reset circuit breaker. It also has an NVR (No-Volt Release) switch, which stops the machine from starting up by accident.
The PD318BT is lightweight and portable, making it easy to move around your workshop. It’s suitable for both hard and soft woods and comes with all the tools you need, including a blade setting jig.
Please note, if you require an EU plug, please ensure you purchase 113504
Dust Extraction Outlet 50 mm
Feed Speed 7 m/min
Knives HSS (Resharpenable) x 2
Overall L x W x H 600 x 360 x 480 mm
Power 1.8 kW
Rating Occasional Use
Min Extraction Airflow Required 390 m³/hr
Plug Fitted UK 3 pin plug
Cuts per Minute 18,000
Cutterblock Diameter 48 mm
Cutterblock Speed 9,000 rpm
Max Depth of Cut Thicknesser 2.5 mm
Max Thicknessing Height 153 mm
Max Thicknessing Width 318 mm
Min Thicknessing Height 5.0 mm
Nett Weight 30 kg
Voltage 230 V
Warranty Perform 1 Year Warranty
EAN Barcode 5052511142330
