Ideal for beginners who are seeking a compact, yet versatile bandsaw
The Perform PD1400B Bandsaw is the ideal choice for those seeking their first bandsaw. Its compact yet versatile design makes it easy to handle a variety of DIY projects while delivering quality cuts every time.
A yellow and black PERFORM band saw stands in a workshop next to a wooden workbench and a red tool cabinet, with a clear dust collector hose attached.
Sturdy and compact
Perfect for smaller workspaces, this bandsaw boasts a compact design that fits easily on any worktable. Its sturdy 300 x 300mm cast aluminium table provides a stable surface for precise and smooth cutting.
Close-up of a metal band saw blade extending downward from a black and silver saw head, with a blurred gray workshop or studio background.
Bearing guides
Top and bottom bearing guides provides easy setup, saves time and ensures accuracy. The top guide has height adjustment, allowing max 80mm depth of cut.
A yellow and black PERFORM brand band saw mounted on a wooden workbench in a workshop setting.
Mitre and rip fence included
The mitre fence allows you to produce accurate crosscuts at any angle, whilst the rip fence ensures for accurate, straight cuts.
A person's tattooed arm and hand are shown adjusting a black knob on the top of a yellow and black Perform band saw in a workshop setting.
Micro switched doors
This feature ensures the machine automatically stops running if a door is accidentally opened, providing an extra layer of safety during use.
A yellow and black Perform brand band saw in use, with a person guiding a piece of wood through the blade in a workshop setting.
Easy table adjustments
The table tilts to 45 degrees for varied cuts, whilst the rack and pinion allows smooth, precise table adjustments.
A close-up of a workshop machine mounted on a wooden workbench, with a clear corrugated dust hose connected to a black motor housing and a yellow support bracket.
Safeguard your health
Connect your bandsaw to a suitable vacuum extractor via the 63mm dust port.
Quick release tension blade
The quick tension release ensures for rapid and simple blade changes.
A close-up of a band saw cutting a piece of material, with a person's hand guiding it. The machine features a bright yellow side panel with a partially visible black logo of the brand Perform and a dark grey metal table.
Perfect for...
Ideal for use on wood, aluminium, plastic and is capable of straight, curved, shallow and deep cuts.
Choose your blade
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The Perform PD1400B Bandsaw is ideal for beginners or small home workshops.
It features a strong chassis with a cast aluminium table, providing a solid, sturdy working area. The machine accommodates blades between 4.8 mm and 9.5 mm wide and offers a maximum cutting height of 80 mm, delivering excellent versatility for a variety of cutting tasks.
Driven by a reliable, quiet induction 250W motor, the PD1400B delivers a blade speed of 960 m/min. It has balanced cast alloy wheels. The top wheel is mounted in a welded steel sub frame with blade tensioning and tracking controls conveniently close. The quick tension release ensures for simple and rapid blade changes.
Bearing blade guides and a thrust bearing provide maximum blade control, ensuring improved accuracy and clean cuts.
The 300 x 300 mm table tilts to 45 , whilst the rack and pinion allows for smooth table adjustment so you can cut at different angles with ease. A mitre fence is included, allowing you to produce accurate crosscuts whilst the rip fence ensure for straight and accurate cuts.
The micro-switched doors ensure the machine automatically stops running if a door is accidentally opened, providing an extra layer of safety during use.
The 28mm dust extraction outlet allows efficient dust collection when connected to a suitable vacuum extractor, helping to maintain a clean and safe workspace.
This compact, yet versatile machine makes an excellent beginner bandsaw. It's great for cutting wood, aluminium and plastic.
Please note, if you require an EU plug, please ensure you purchase 113504
Dust Extraction Outlet 63 mm
Max Width of Cut with Fence 130 mm
Overall L x W x H 420 x 400 x 690 mm
Power 250 W
Rating Occasional Use
T Slot Size 10.5 x 3.5 mm
Table Height 320 mm
Table Size 300 x 300 mm
Table Tilt 0 - 45
Min Extraction Airflow Required 200 m³/hr
Plug Fitted UK 3 pin plug
Model PD1400B
Bandsaw Blade Length 1,400 mm (55")
Bandsaw Wheel Diameter 200 mm
Blade Width Min\Max 4.8 mm to 9.5 mm
Max Cutting Height 80 mm
Max Width of Cut 195 mm
Nett Weight 17 kg
Voltage 230 V
Warranty Perform 1 Year Warranty
EAN Barcode 5052511142194
Accessories
  • Axcaliber Pack of 3 Blades for PD1400B Bandsaw
  • Axcaliber High Carbon Bandsaw Blades Axcaliber High Carbon Bandsaw Blades
  • Axminster Push Stick
    $6.99 USD
