Built for everyday workshop tasks
Take on everyday workshop jobs with ease using this versatile bench grinder, perfect for sharpening, shaping and cleaning up rough edges.
A yellow and black grinder stored inside an open wooden cabinet with light wood doors and black handles.
Compact design
Compact in size, the PD150BG Bench Grinder is easy to store away when not in use, whether it be under a bench or on a shelf, ideal for smaller workspaces.
A close-up of a Perform bench grinder being used on a piece of metal, with a person's hand adjusting a clear guard. The grinder has a black base, a white and yellow abrasive wheel, and red accent rings, set on a wooden workbench.
Sturdy construction
Combining cast iron, pressed steel and impact resistant perspex, it's durable and sturdy for reliable results.
A close-up of a yellow PERFORM PD150BG angle grinder in use, sharpening a piece of metal with a white abrasive wheel. A human hand is visible holding the workpiece, and the background is a wooden surface.
Adjustable tool rests
Designed for ease of use, the grinder features adjustable tool rests that can be moved to maintain the correct gap to the wheels as they wear.
A close-up of a person's hands adjusting a clear acrylic guide on a yellow and grey bench grinder, set on a wooden workbench.
Adjustable eye shields
Protect yourself against sparks and debris with the adjustable eye shields.
Sparks on a Perform bench grinder
Integrated spark arrestors
The integrated spark arrestors deflect sparks and improve visibility during use.
A close-up action shot of a person sharpening an axe handle on a yellow and black Perform grinder with a clear guard, set on a wooden workbench.
Perfect for...
Ideal for general grinding, sharpening, shaping and deburring.
Complete your setup...
Get more from your Perform Bench Grinder with a selection of practical accessories. Improve sharpening accuracy with the Axminster Adjustable Sharpening Rest, keep grinding wheels flat and performing efficiently using the Axminster Diamond Dressing Block, and stay protected from sparks and debris with reliable workshop eye protection.
More Grinding & Polishing Accessories
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The Perform PD150BG 150mm Bench Grinder is a compact, light use grinder, well suited for general sharpening and light grinding tasks in the home workshop. It is also handy for shaping metal and deburring. Compact in size, it's easy to store away when not in use, whether under the bench, on a shelf or in a smaller workspace.
Designed for ease of use, the grinder features adjustable tool rests that can be moved to maintain the correct gap to the wheels as they wear. Clear eye shields are fitted to help protect against sparks and debris, while integrated spark arrestors deflect sparks and improve visibility during use.
Built with durability in mind, the PD150BG Bench Grinder combines cast iron, pressed steel and impact-resistant perspex in its construction. The 150mm wheels are powered by a smooth running 250W induction motor, delivering a wheel speed of 2,980rpm. Each wheel is 20mm wide, mounted on a 12.7mm spindle, offering versatility for a range of basic grinding applications. The wheels are 80g and 120g white wheels.
Measuring 350 x 235 x 235mm overall and weighing 6.5kg, the grinder is stable in use yet light enough to move and store when needed. The Perform PD150BG is an excellent choice for those looking for a reliable and accessible light use grinder.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 350 x 235 x 235 mm
Rating Occasional Use
Motor Power 250 W
Plug Fitted UK 3 pin plug
Model PD150BG
Grinding Wheel Diameter 150 mm
Nett Weight 6.5 kg
Spindle Diameter 12.7mm
Voltage 230 V
Warranty Perform 1 Year Warranty
Wheel Speed 2,980 rpm
Wheel Width 20 mm
EAN Barcode 5052511142101
