The Festool KAPEX KS60 combines portability with Festool’s faultless build quality. It has a compact and lightweight design, with ergonomic handgrips, an integrated cord holder and locking device for safe transportation. This is an ideal compound mitre saw for any professional, guaranteeing accurate results out on site or in the workshop. It will swivel to 60 on both sides with indents at 0°, 15, 22.5, 30, 45 and 60 for quick setting of common angles. The head tilts for bevel cuts 47 to the left and 46 to the right, with stops at 45 for fast setup. For straight crosscuts, the KS60 is capable of cutting boards and panels up to 305mm wide and trimming strips, profiles and square timber up to 60mm thick. The electronically controlled smooth start-up ensures that the machine starts up jolt-free. Variable speed control, from 1,300 to 3,500rpm, allows you to adjust the saw’s speed to the material you wish to cut. Integral extension tables on both sides, pull out to support longer workpieces.
The KAPEX KS60 E-SET comes with 3 very useful accessories. A set of additional feet raise the KS60 table to the exact height of a SYSTAINER SYS 1 case. This enables you to support long workpieces, without the need to scrabble around for odd packing pieces. The LED spotlight gives you a perfect view of the cutting line, especially useful in poorly illuminated situations. The cleverly designed bevel guarantees you fault-free angle transfer both internal and external. The bevel automatically bisects an angle allowing you to set the KAPEX KS60 precisely when cutting skirting boards or cornices.
Supplied with 216mm Festool Universal wood HW blade 23mm kerf 36 tooth.
Bevel Angle Range 47 - 0 - 46
Dust Extraction 27 mm / 36 mm Outlet
Mitre Angle Range 60 - 0 - 60
Overall L x W x H 661 mm x 475 mm x 430 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 216 mm
Sound Power Level LwA [Uncertainty K] 100 dB(A) [3.0 dB]
Blade RPM 1,400 - 3,400 rpm
Sound Pressure Level LpA [Uncertainty K] 91 dB(A) [3.0 dB]
Motor Power 1,200 W
Manufacturer Part Number 561729 & 561693
Model KAPEX KS 60 E-SET
Bore Size 30 mm
Max Bevel Cut @ 45º W x H 305 mm x 40 mm
Max Compound Cut @ 45º W x H 215 mm x 40 mm
Max Crosscut @ 0º W x H 305 mm x 60 mm
Max Mitre Cut @ 45º W x H 215 mm x 60 mm
Nett Weight 17.8 kg
Voltage 230 V
Voltage 230 V
EAN Barcode 4014549243077
