The Festool KAPEX KSC 60 cordless sliding compound mitre saw combines the freedom of a battery powered tool with the performance of a mains powered machine. The brushless EC-TEC motor coupled with dual 18V battery power can provide enough runtime for a typical full day's work. The KSC 60 produces unbeatable precise crosscuts. Mitre angles of up to 60 on each side with indents at common angles and bevel angles 47 L and 46 R, with stops at 45 for fast setup.
The twin guide bars with two bearings each ensure that the saw blade moves smoothly and precisely at every angle; making every cut perfect. The variable speed can be preset for the best results for the material in use. The low weight, compact design and convenient handles make this easily portable for work on site. An LED spotlight highlights the cutting line ensuring good visibility of a scribed cutting line. A large dust bag is supplied making for a cleaner workspace even without a mobile dust extractor. Pull out extension tables on each side provide support for longer workpieces.
The additional feet bring the height of the KSC 60’s table to the exact same height of an SYS 3 M 112 or SYS 1 Systainer case.
Includes a Festool bevel which transfers interior or exterior angles to the saw for a perfect mitre every time.
Supplied with; dust bag, clamp, additional feet, 36 tooth TCT blade and Bevel SM-KS.
Please Note; this is a body only machine supplied without batteries or charger.
Part of the Festool 18V family.
Battery Voltage 36 V (2 x 18 V)
Bevel Angle Range 47 - 0 - 46
Dust Collection Dust Bag Supplied
Dust Extraction 27 mm / 36 mm Outlet
Mitre Angle Range 60 - 0 - 60
Overall L x W x H 639 mm x 459 mm x 442 mm
Spindle Lock Standard Feature
Blade Diameter 216 mm
Sound Power Level LwA [Uncertainty K] 100 dB(A) [1.5 dB]
Battery Type Li-ion
Blade RPM 1,300 - 3,500 rpm
Sound Pressure Level LpA [Uncertainty K] 91 dB(A) [1.5 dB]
Vibration Cutting Wood [Uncertainty K] 2.5 m/s² [3.0 m/s²]
Manufacturer Part Number 576847
Model KSC 60 EB- Basic
Bore Size 30 mm
Electric Brake Standard Feature
Max Bevel Cut @ 45º W x H 305 mm x 40 mm
Max Compound Cut @ 45º W x H 215 mm x 40 mm
Max Crosscut @ 0º W x H 305 mm x 60 mm
Max Mitre Cut @ 45º W x H 215 mm x 60 mm
Nett Weight 18 kg
EAN Barcode 4014549382240
