The Fiskars X24 is engineered to deliver efficient splitting performance on small to medium logs where accuracy, power and ease of use matter most. Designed for logs between 10–20 cm in diameter, its compact blade profile and integrated splitting wedge drive deeply into timber while making removal smooth and effortless. The advanced blade‑grinding geometry produces a sharp, clean edge for effective splitting, while the double‑hardened, forged steel construction ensures the blade stays sharp for longer. A low‑friction coating reduces resistance with each strike and helps protect the blade from rust.
Safety and durability are built into every part of the axe. The secure, undetachable head‑to‑shaft connection gives complete confidence during repeated heavy impacts, and the ultralight FiberComp™ shaft is virtually unbreakable while providing excellent overstrike protection. Perfectly balanced weight distribution maximises the power delivered with each swing, and the oversized SoftGrip™ handle with strategic texturing offers comfort, stability and control. A hooked end adds extra security in the hand during use, ensuring a confident grip from start to finish.
With more than 375 years of design heritage, Fiskars is recognised worldwide for creating tools that combine superior performance with outstanding ergonomics. Designed in Billnäs, Finland, the X24 reflects Fiskars’ longstanding expertise in crafting durable, high‑performance cutting tools trusted by professionals, woodworkers and homeowners alike.
The Fiskars X24 Splitting Axe is ideal for preparing small to medium‑sized logs for firewood, offering controlled, powerful splitting with minimal effort.
Looking for a different size or splitting power? Explore the full Fiskars axe range for smaller, larger, and extra‑powerful options.
A protective sheath is included for safe storage, and the axe is backed by a 25‑year warranty.
Length: 600 mm (24)
Overall Length 600 mm (24)
EAN Barcode 6411501201645
