Perform PD216SMS Slide Mitre Saw; angles made easy
Take out the guesswork when it comes to cutting at an angle. The Perform PD216SMS Slide Mitre Saw is a versatile, entry level saw designed for light use, delivering excellent results for DIY or home workshop tasks.
A Perform Mitre saw with a black and yellow blade guard, set on a wooden workbench inside a workshop with shelves of wood and a red tool chest in the background.
Space saving design
Forward-facing guide rails allow the saw to be positioned close to the wall, saving valuable workshop space.
A person in a red and blue plaid shirt operates a yellow and black mitre saw cutting a piece of wood in a workshop setting with tools hanging on the wall.
Cutting capacity
The saw boasts an impressive 80mm cutting depth and a 305mm width; plenty of capacity for your home projects or DIY tasks. The left and right hand pull-out extension bed supports longer lengths of timber when cutting.
A silver and black clamp attachment mounted on a light wood board, positioned in front of a black mitre saw with a person's tan shirt visible on the left side.
Secure clamping
Securely hold timber in place using the material clamp to prevent movement and enhance safety.
Close-up of a mitre saw cutting a light wood board, showing the black and yellow PERFORM brand saw with a clear blade guard.
Perfect accuracy
The mitre saw's light casts a precise shadow indicating where the cut will be made, making it easier to align and visualise.
A yellow and black mitre saw in use on a wooden board, with a person's hands guiding the wood. The saw is positioned on a workbench in a workshop setting with various hand tools hanging on a wall behind it.
Cut at a range of angles
The saw accommodates mitre cuts 0° to 47° left and right, as well as bevel cuts to the left at 0° to 47°.
Close-up of a Perform mitre saw with a bright yellow blade guard and black metal components, showing the PERFORM branding.
Quality blade
Supplied with a 36 tooth Teflon coated contract quality blade from Axcaliber. This helps to prevent resin build up on the blade.
A yellow and black Perform mitre saw with a blue vacuum hose connected to its dust port, set against a white brick wall background with workshop tools.
Safeguard your health
Many mitre saws have poor extraction, but with this one there is a dust bag supplied, or you can connect your saw to a suitable vacuum extractor via the 38mm port.
A yellow and black mitre saw on a workbench in an outdoor setting, with a person's hands guiding a piece of wood through the blade.
Perfect for...
Ideal for decking, outdoor projects, cutting trim and mouldings and more, it makes for a great beginner saw or for those using lightly.
Browse the accessories...
This 216 mm saw blade set comprising a 36-tooth blade and a 56-tooth blade is ideal for smooth, precise, and safe cutting. Both blades feature a Teflon coating to reduce heat buildup and friction, ensuring cleaner cuts and extended blade life.
Add the blade package
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The Perform PD216SMS Slide Mitre Saw is a compact tool designed with cutting versatility and space saving in mind. Featuring a forward facing guide rail system, this saw can be positioned closer to the wall - ideal for workshops with limited floor space.
Equipped with a 1.4kW motor and a 216mm diameter blade, the PD216SMS delivers a blade speed of up to 5,000rpm, enabling smooth and precise cuts across a variety of materials. The Teflon-coated blade offers contract-grade performance straight out of the box.
This mitre saw supports a wide range of cutting angles, mitring from 0 to 47 in both directions and beveling to the left from 0 to 47, making it suitable for a variety of angled cuts. Trenching cuts can be achieved by adjusting the depth stops. Achieve precise cuts with the mitre saw's shadow line, clearing indicating the exact cutting path for easy alignment. Use the clamp to securely hold the timber in place, preventing any movement and enhancing safety. With a generous cutting capacity of up to 305mm wide and 80mm deep, the saw also features left and right pull-out extension bed supports for handling longer lengths of timber.
To help keep your workspace clean, a dust bag is provided or there's a 38mm dust extraction outlet that you can connect to a vacuum extractor.
Ideal for tasks such as decking, trim, moulding, and other indoor or outdoor woodworking projects, this saw is perfect for beginners or as a reliable, light-duty addition to any workshop.
Please note, if you require an EU plug, please ensure you purchase 113504
Bevel Angle Range 0 - 47
Dust Collection Dust Bag Supplied
Dust Extraction 38 mm Outlet
Mitre Angle Range 0 - 47
Overall L x W x H 725 x 465 x 500 mm
Spindle Lock Standard Feature
Table Size 420 x 110 mm
Blade Diameter 216 mm
Sound Power Level LwA [Uncertainty K] 92 dB(A)
Corded or Cordless Corded
Blade RPM 5,000 rpm
Sound Pressure Level LpA [Uncertainty K] 104 dB(A)
Motor Power 1,500 W
Plug Fitted UK 3 pin plug
Web Attribute Set Mitre Saws Mains Powered
EAN Barcode 5052511143245
Accessories
  • Perform Quick Clamp Perform Quick Clamp
    £104.98
  • Perform Quick Bench Perform Quick Bench
    £41.99 £59.98 Save £17.99
  • Perform 216mm Saw Blade Package (Pkt 2) Perform 216mm Saw Blade Package (Pkt 2)
  • Axcaliber CutPro TCT Saw Blade Neg Rake - 216mm x 2.5mm x 30mm 56T Axcaliber CutPro TCT Saw Blade Neg Rake - 216mm x 2.5mm x 30mm 56T
