Keep your workspace clean and safe
The Perform PD57E Dust Extractor helps you keep your tools in great shape and your workspace clean. It’s perfect for hooking up to high-volume machines to clear away dust and wood chips with ease.
A man wearing red ear muffs and a red and blue plaid shirt operates a table saw in a workshop. A yellow and white PERFORM dust collector stands behind him, and wood shelves and a red tool chest are visible in the background.
Filtration level
With a high emission rating of 5 microns and a 1HP motor, the extractor is suitable for high volume machines.
A close-up of a black metal extraction hood with a flexible grey hose, shown sucking up wood shavings on a wooden floor.
Efficient floor cleaning
The extractor is supplied with a floor sweeping attachment for easy and efficient floor cleaning, keeping your workspace tidy.
A clear dust collection bag filled with wood shavings or sawdust, attached to a yellow and black machine with a flexible clear hose in a workshop setting.
High volume air flow
With 850m3/hr of air flow, the extractor is efficient in capturing dust and wood chips, helping to keep your tools in good condition.
A yellow and black dust extractor with a clear plastic collection bag, shown in a workshop setting with wood panels in the background.
Large capacity
A 57L bag capacity minimizes the need for frequent emptying, ensuring long-lasting performance. There are bottom bag spring clips to make changing bags simple and easy.
A person wearing a red plaid shirt and jeans stands next to a yellow and black Perform dust extractor with a clear plastic collection bag, set in a workshop with a wood floor and white cinderblock wall.
Portable
Mounted onto 4 castors, the extractor is easy and convenient to move across your workspace.
A person in a red and blue plaid shirt stands behind a yellow Perform planer thicknesser connected to a dust collection system in a workshop, holding a piece of wood while dust is collected in a clear container.
Perfect for...
Clearing waste from high volume machines such as a planer thicknesser, keeping your space safe and clean.
A simple step for a safer workspace
When setting up your PD57E Dust Extractor, don’t forget the hose! It connects your machine to the extractor, so all the dust is safely carried away - keeping your workspace tidy and your lungs happy.
Shop now
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The Perform PD57E 1HP Dust Extractor is a compact yet powerful solution for maintaining a cleaner workspace. With a robust 750W motor, it efficiently captures dust and debris from high-volume machines like planer thicknessers. The large 57-litre collection bag provides ample waste capacity, while the upper cloth filter bag delivers 5-micron filtration to help reduce airborne dust. Practical bag hooks allow for quick and easy bag changes, keeping workshop downtime to a minimum.
Built for ease of use and mobility, the PD57E includes four swivel castors for smooth movement and a floor sweeping attachment for quick cleanup of workshop floors. Its 100mm hose diameter ensures compatibility with a wide range of tools. Its compact footprint (800mm x 420mm x 1,550mm) makes it suitable for space-conscious environments. Weighing just 27kg, this extractor offers a practical balance of performance, portability, and value for entry-level users or light workshop use.
Airflow as measured in the Axminster workshop is 850m3/h @ 100mm.
Please note, if you require an EU plug, please ensure you purchase 113504
Airflow 850 m³/hr @ 100 mm
Filter Performance 5 micron
Overall L x W x H 800 x 420 x 1,550 mm
Power 750 W
Rating Occasional Use
Sound Power Level LwA [Uncertainty K] 77 dB(A)
Plug Fitted UK 3 pin plug
Web Attribute Set Coarse Dust & Chippings Extractors
EAN Barcode 5052511142279
