The Axminster Professional AP32FD Floor Drill is designed to offer premium performance and reliability for professionals and advanced hobbyists alike. This high-performance floor drill is engineered for precision and stability, making it ideal for a variety of drilling tasks. It boasts a powerful 1,100W induction motor, 12 adjustable speed settings ranging from 150 to 2,700rpm, and a large, stable base to ensure consistent accuracy.
The AP32FD Floor Drill includes a large table with rack and pinion height adjustment, which can tilt and swivel away to allow the base to be used as a work support. The switch system features a separate locking emergency stop switch and a separate switch for the integrated, adjustable LED work light. For added safety, the chuck guard and belt cover are electrically interlocked. This floor drill also features a 3MT precision spindle running in genuine NSK ball bearings, ensuring accurate drilling and low vibration.
This model includes several key upgrades, such as a heavy-duty chuck and a redesigned chuck guard with a fitted seal. The high-quality chuck enables quick and easy bit changes. An improved depth stop design allows for precise drilling depth adjustments. The AP32FD also boasts improved motor mounting and enhanced soundproofing between the drill head and guard, contributing to a quiet and smooth operation.
Whether you are upgrading from an older model or looking for a reliable floor drill for your workshop, the Axminster Professional AP32FD Floor Drill offers the perfect combination of power, precision, and durability. This professional floor drill is a must-have for anyone seeking a durable and versatile drilling machine.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 860 mm x 610 mm x 1,710 mm
Power 1.1 kW
Rating Frequent Use
Table Size 475 mm x 425 mm
Table Tilt 90 - 0 - 90
Chuck Capacity 3 mm to 16 mm
Chuck Type keyless
Throat Depth 254 mm
Plug Fitted UK 3 pin plug
Web Attribute Set Drilling Machines
EAN Barcode 5052511136360
  • UK Mainland - £70
