Replacement tips for the UJK Pocket Hole Drill with 12mm Bit, manufactured from M2 steel and available in sizes 30mm / 22mm / 12mm.
Broken the tip off your UJK Pocket Hole drill? No need to buy a whole new drill bit! The UJK Pocket Hole Drill with 12mm Bit allows interchangeable and replaceable tips.
Overall Length \ Working Length 22 mm
Intended Use Drill bit for use with pocket hole jigs.
EAN Barcode 5052511136698
