A fine dovetail set for cutting 6.3 mm dovetails with the Axcaliber dovetail jig when making small boxes, drawers or similar items. Supplied complete with a Trend style guide bush to fit many routers or the Axminster Universal Base and a solid TCT dovetail cutter. It can also be used for cutting comb joints using the same guide bush and a 5.4 mm straight cutter (666267). Width capacity 275 mm material thickness 7 mm to 10 mm.
Axcaliber
Axcaliber Fine Dovetail Set
| Web Attribute Set | Dovetail Router Jigs |
| EAN Barcode | 5052511021079 |
