Simple to set up and use, the Axminster Dovetail Jig is very robustly made from heavy gauge steel pressings. Fitted with cam action clamps, the workpieces are held quickly and securely while the smooth anodised finish on the 6mm thick machined finger template ensures that both parts of the joint are cut accurately and cleanly. Full instructions are supplied along with a quality bearing guided dovetail cutter. The jig can be used with any router with a base diameter not exceeding 160mm that will take 1/4
Axcaliber
| Web Attribute Set | Dovetail Router Jigs |
| EAN Barcode | 5052511054282 |
