Perform PD405FS Scroll Saw with Flexible Shaft
If you’re considering your first scroll saw, the Perform PD405FS is a reliable and versatile option. It supports a wide range of scrolling techniques, allowing you to either start cuts from a drilled hole inside the material or begin at the edge and work your way inward.
A person wearing safety glasses guides a piece of wood through a yellow scrollsaw mounted on a workbench, with a clear plastic guard visible around the blade area.
Versatile with large capacity
The PD405FS offers a generous table size allowing for larger projects (410 x 254mm) with a 406mm (16”) throat which tilts to 45̊ for bevel cutting.
A close-up of a person's hands using a black rotary tool with a copper-colored metal bit on a light wood table, with a clear plastic organizer box containing various small metal bits nearby.
Flexible shaft
A flexible shaft and accessory kit are included; with grinding, polishing and sanding accessories for intricate details.
A close-up of a person's hand adjusting a control knob on a scrollsaw, with a green and red power switch visible on the side.
Variable speed
The variable speed capacity allows you to utilise your machine for many different materials.
A yellow and black PERFORM band saw scrollsaw mounted on a wooden workbench, with a flexible shaft attached
Stable build
The base is crafted from heavy cast iron, ensuring minimal vibration for your projects.
A yellow and black PERFORM PD405FS scrollsaw  with a silver circular blade guard and several blades, shown on a wooden surface.
Accepts a range of blades
The saw accepts both pinned and plain end blades. What's more, blade changing is simple thanks to a quick release tension knob.
A yellow and black PERFORM PD405FS circular saw table saw attachment mounted on a wooden workbench, with a blue and black dust hose connected.
Safeguard your health
Connect your scroll saw to a vacuum cleaner via the 35mm diameter dust port.
A person using a yellow and black scroll saw to cut a piece of wood with a clear safety guard in a workshop setting.
Tilting table
The table tilts to 45 degrees for bevel and angled cuts.
A yellow Perform scrollsaw with a clear guard, shown on a wooden workbench with scrollsawed wooden pieces including a horse head, heart, fish, and a decorative plate.
Perfect for...
This scroll saw is perfect for making jigsaw puzzles, small wooden toys and more small craft related items.
A close-up of a scrollsaw in action, cutting decorative star and flame patterns onto a light-colored wooden board.
Choose from a selection of scroll saw blades
From woodcutting to metal-cutting, explore our wide selection of high-performance blades, available in variety of TPI (teeth per inch) configurations to suit every material and application.
Shop now
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
More than just a scroll saw, the PD405FS is a versatile hobby station designed for creative and detailed work. It includes a flexible shaft with an accessory kit, making it suitable for a wide range of hobbyist applications.
Powered by a robust DC motor, the PD405FS features variable speed control to accommodate a variety of materials up to 50mm thick. Independently pivoting blade arms deliver a near-vertical cutting action, helping to achieve cleaner, more precise results.
A generous 406mm throat and tilting table provide ample working space, while the saw is compatible with both pinned and plain-end blades. Blade changes are quick and straightforward thanks to easily accessible clamps. To maintain a clear view of the workpiece, the saw includes an integrated blower, and a 35mm dust port enables connection to a vacuum system for effective dust extraction. The heavy cast iron base adds stability and reduces vibration for improved control.
A truly useful bonus is the power take off with a flexible shaft, for adding fine detail to your work. The supplied accessory kit includes a comprehensive selection of sanding, polishing, cutting, and grinding attachments.
Also included are a blower nozzle, eye guards, and essential service tools. The PD405FS is an ideal machine for those wishing to start a new hobby.
Please note, if you require an EU plug, please ensure you purchase 113504
Dust Extraction Outlet 35 mm
Max Depth of Cut @ 90º 50 mm
Overall L x W x H 630mm x 290mm x 350mm
Rating Occasional Use
Stroke Length 15 mm
Table Size 410mm x 254mm
Table Tilt 0 - 45
Throat Depth 406 mm
Motor Power 125 W
Plug Fitted UK 3 pin plug
Model PD405FS
Nett Weight 10.8 kg
Strokes per Minute 550 - 1,600 (var)
Voltage 230 V
Warranty Perform 1 Year Warranty
EAN Barcode 5052511142187
