A very versatile jaw set; originally designed for the SK114 chuck but is equally suitable for use on the GK100 and SK100. Initially named Piranha jaws, due to their incredible ‘bite’ they expand into an 85mm recess or contract onto a 62mm spigot. The 40mm deep jaw has a series of ridges giving the jaw immense holding power. These given dimensions are when the jaws form a true circle and offer the best grip. However, the amount of movement available offers a range of 57mm to 72mm internal and 77mm to 93mm external. These jaws are an excellent choice for hollow forms or turning unseasoned timber. Made from stainless steel to protect against corrosion. As with all the Axminster Woodturning Dovetail Jaws they simply bolt onto the Accessory Mounting Jaws.
Axminster Woodturning Deep Grip Jaws
| Made in Britain | Yes |
| Jaws For 114mm Chuck | Yes |
| Intended Use | For gripping hollow forms or unseasoned wood during woodturning. |
| Web Attribute Set | Jaws for Four Jaw Chucks |
| EAN Barcode | 5052511096916 |
