Axminster Woodturning
Axminster Woodturning Spindle Roughing Gouge M2 Cryo - 19mm (3/4")
SKU: 113215
€48,00
  • Perfect for removing corners of square stock
  • M2 cryogenically treated HSS blade
  • Well-shaped, Ash wood handles
  • Supplied in a 100% recyclable packaging
Ideal for removing the corners of square stock, and to reduce the size of the blank. The blade is M2 high speed steel that has been cryogenically treated. This ensures that the edge lasts 5 times longer than typical high speed steel. The blade is fitted to a well-shaped, Ash wood handle that provides a strong and sturdy grip. Supplied in a cardboard tube, 100% recyclable.
Overall length 320mm.
EAN Barcode 5052511141708
