Easy Wood Tools
Easy Wood Tools Micro EASY FINISHER™
SKU: 109203
€98,00
  • Use for small, fine detail or delicate turning projects
  • Finisher for coves, hollows, sweeping curves and final shaping
  • No need to sharpen;, simply rotate cutter to a fresh edge
  • Solid carbide tip keeps an edge many, many times longer than HSS
  • Use to turn dry or green wood, acrylics and resin
  • 8mm square section bar ensures the tool sits flat and steady
  • American Maple handle with copper ferrule for strength
The Easy Wood Tools Micro Easy Finisher™ is a carbide woodturning tool designed for creating smooth curves, refining shapes, and final surface preparation on small workpieces such as pens, bottle stoppers, ornaments, and miniature spindle projects.
As part of the Micro range, it is ideal for precise finishing work where control and accuracy are essential.
Fitted with a round replaceable carbide cutter, the Micro Easy Finisher™ produces smooth, flowing cuts with minimal effort. Its compact size and flat‑profile bar allow the tool to sit securely on the rest, making it easy to maintain control without needing to master complex tool angles or sharpening techniques.
The Micro Easy Finisher™ is designed to deliver clean, consistent finishing cuts, helping to refine curves and remove tool marks left by roughing. It excels at smoothing both the inside and outside of small forms.
When used parallel to the floor at centre height, the flat bar ensures stability on the rest, helping reduce catches and allowing for controlled, confident finishing — particularly important on delicate or small‑diameter work.
Easy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
Specifications
Tool type: Micro carbide finishing tool
Cutter type: Round carbide cutter
Range: Micro (compact for small projects)
Bar profile: Flat section for stability on the tool rest
Handle: Hardwood with copper ferrule
Negative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to produce a smoother, finer finish on delicate or hard materials.
Replacement Tip Ci5 (109316)
EAN Barcode 5052511133345
