Easy Wood Tools
Easy Wood Tools Mid-Size EASY FINISHER™
SKU: 109311
€130,00
  • Versatile go‑to finisher for bowls, platters, boxes and spindles
  • Finisher for coves, hollows, sweeping curves and final shaping
  • No sharpening required - simply rotate the carbide cutter to a fresh edge
  • Solid carbide cutter keeps an edge many times longer than HSS
  • Suitable for dry or green wood, acrylics, and resin
  • 9.5mm sq section bar sits flat and steady on the tool rest for easy control
  • 350mm American maple handle, copper ferrule for strength and leverage
The Easy Wood Tools Mid‑size Easy Finisher™ is a carbide woodturning tool designed for making coves, hollows, sweeping curves, and final shaping on bowls, platters, boxes, spindles, and other projects.
Offering greater reach and versatility than the Easy Start range, it’s the perfect go‑to finishing tool for turners working on medium to larger workpieces.
Featuring a replaceable round carbide cutter and a 9.5mm square section bar that sits flat on the tool rest, the Mid‑size Easy Finisher™ delivers excellent stability and easy control with no sharpening required.
The extended 350mm American maple handle provides increased leverage and balance, making it ideal for smoothing forms and refining curves on deeper or broader pieces.
Designed for smooth, flowing cuts, the Mid‑size Easy Finisher™ excels at cleanly refining shapes, hollow forms, and gentle curves.
With the tool held parallel to the floor at centre height, the square bar keeps the tool steady on the rest, helping to virtually eliminate catches and snatches, making finishing cuts predictable and confidence‑building.
With no sharpening required, simply loosen the fixing screw and rotate the cutter to a fresh edge when dull.
Easy Wood Tools’ long‑lasting carbide holds an edge many times longer than HSS and works effectively on dry or green wood, acrylics, and resin.
Each shaft is engraved with its carbide cutter reference number for easy identification.
What you get
Round carbide cutter fitted as standard
Hex key for quick cutter rotation or replacement
350mm American maple handle with copper ferrule for strength
Colour‑coded handle for easy identification across the range
Specifications
Overall length: 533mm
Bar profile: 9.5mm square section
Optional upgrade
Negative rake carbide cutters are available separately and work particularly well on acrylics, polyester, and resin materials, producing a finer, smoother finish on timber for higher‑quality shaping and surface refinement.
Replacement Tip Ci3 (109312)
