The Easy Wood Tools Mid‑size Micro Easy Detailer™ is a carbide woodturning tool designed for creating small coves, delicate beads, and ultra‑fine decorative details on bowls, platters, boxes, spindles, and other projects.
Offering greater reach and stability than the micro range, but finer precision than the standard Mid‑size Detailer, it is the ideal go‑to tool for intricate finishing work on larger workpieces.
Equipped with a replaceable carbide cutter and a 9.5mm square section bar that sits flat on the tool rest, the Mid‑size Micro Easy Detailer™ delivers exceptional stability and easy, predictable control with no sharpening required.
The extended 350mm American maple handle gives added leverage and balance, making delicate cuts feel safer and more controlled - even on deeper or larger forms.
Purpose‑built for intricate detail work, this tool excels at producing clean, consistent ultra‑fine details with minimal effort.
With the tool held parallel to the floor at centre height, the square bar keeps the tool flat on the rest, helping to virtually eliminate catches and snatches - ideal for delicate finishing cuts on both spindles and faceplate work.
With no sharpening needed, simply loosen the fixing screw and rotate the cutter to a fresh edge when dull.
Easy Wood Tools’ long‑lasting carbide holds an edge many times longer than HSS and can be used on dry or green wood, acrylics, and resin.
Each shaft is engraved with its carbide cutter reference number for quick identification.
What you get
Carbide cutter optimised for ultra‑fine detail
Hex key for quick cutter rotation or replacement
350mm long American maple handle with copper ferrule for strength
Colour‑coded handle for easy identification across the range
Specifications
Overall length: 533mm
Bar profile: 9.5mm square section
Optional upgrade
Negative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin materials, producing a smoother, finer finish on timber as skills develop.
