Easy Wood Tools
Easy Wood Tools Mini EASY HOLLOWER™ #3
SKU: 109275
€120,00
  • Turn ornaments, mini vases, and other small hollow forms
  • Mini Hollower #3; bent shaft for easier access to deep undercuts
  • Negative Rake Carbide Cutter minimises the risk of a catch
  • Square section shaft provides excellent stability
  • Carbide cutter keeps its edge many, many times longer than HSS
  • No need to sharpen; simply rotate cutter to a fresh edge
  • American Maple handle with copper ferrule for strength
The Easy Wood Tools Mini Easy Hollower™ #3 is a carbide woodturning tool designed for final interior shaping and deeper hollowing of small hollow forms, vessels, and compact bowls.
As the third stage in the Mini hollowing system, it is used to refine the internal surface, improve wall consistency, and complete the hollowing process after initial shaping.
Fitted with a replaceable carbide cutter and a rigid hollowing shaft, the Mini Easy Hollower™ #3 offers precise control when working deeper inside smaller forms.
Its compact size with added stability over Micro tools gives a confident, balanced feel, while the tool’s profile sits securely on the rest.
With no sharpening required, it keeps the focus on refining the form rather than maintaining the tool.
The Mini Easy Hollower™ #3 is designed for controlled deep‑reach refinement, allowing you to smooth and finish the interior walls of small hollow forms.
Its shaft design helps reduce vibration and maintain stability as you work further from the tool rest, and when used parallel to the floor at centre height, it delivers clean, predictable cuts. This makes it ideal for completing the hollowing process after the bulk removal of #1 and shaping of #2.
Easy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
Specifications
Tool type: Mini carbide hollowing tool (#3 – final shaping stage)
Cutter type: Carbide hollowing cutter
Range: Mini (compact tools for small hollow forms)
Shaft design: Hollowing shaft for extended reach and internal finishing
Handle: Hardwood with copper ferrule
Negative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to achieve a smoother finish and improved control when refining deeper or more delicate areas.
Replacement Tip Ci5-NR (109317)
