Effective extraction for small home workshops
Designed for light-duty applications, the PD50E Wood Dust Collector offers an ideal alternative to domestic vacuum cleaners. It efficiently handles wood dust and chips, helping maintain a clean and tidy workspace.
A yellow Perform PD50E collector with a black top and side attachments, positioned in a workshop next to a wooden workbench and a red tool chest.
Small and compact
Easy to store when not in use, the compact design makes the collector ideal for those with smaller workspaces. It also has a grab handle, so it’s easy to move.
A person with tattooed arms lifts a black lid off a bright yellow dust extractor PERFORM PD50E, set on a wooden workbench against a grey brick wall.
Closed filter system
All filtration takes place within the machine itself, effectively capturing and containing the majority of fine dust particles to ensure cleaner air.
A person holds a pleated air filter with an orange top edge next to a yellow extractor labelled PERFORM. The person is wearing a dark grey t-shirt and standing behind a wooden table against a grey brick wall.
Filtration level
The 2-stage filtration comprising of a cartridge filter and outer paper filter provides fine filtration, removing 99% of particles greater than 1 micron.
A person operating a yellow and black PERFORM band saw and dust collector setup in a workshop. A yellow PERFORM shop vacuum connected by a clear hose is positioned on the floor next to the workbench.
Compatible with bench top machines
Featuring a 63mm inlet, this wood dust collector is specifically designed for use with benchtop machines, delivering efficient and reliable dust extraction.
A simple step for a safer workspace
When setting up your PD50E Dust Extractor, don’t forget the hose! It connects your machine to the extractor, so all the dust is safely carried away - keeping your workspace tidy and your lungs happy.
Shop now
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The PD50E is a practical solution for dust and chip extraction in small home workshops, offering a dedicated alternative to using a domestic vacuum cleaner. Compact in design, the unit features a 50-litre drum with a 420mm diameter and stands 730mm tall, making it space-efficient and easy to position within limited workshop areas.
Equipped with a two-stage filtration system-comprising a cartridge filter and an outer paper filter-the PD50E provides effective fine particle filtration, capturing 99% of particles greater than 1 micron. The extractor includes a 63mm inlet for connecting to compatible workshop tools and accessories.
The power head features an integrated carry handle for portability and is secured to the drum with a robust metal quick-release strap. Airflow performance: measured in our workshop is 440m³/hr @ 63mm.
Supplied with a spare set of carbon brushes for easy maintenance.
N.B. Extraction hose not included.
Please note, if you require an EU plug, please ensure you purchase 113504
Airflow 440 m³/hr @ 63 mm (28-40 m/s)
Filter Performance 99% 1 micron
Inlet 63 mm
Overall L x W x H 420mm x 420mm x 670mm
Power 1.2 kW
Rating Occasional Use
Sound Pressure Level LpA [Uncertainty K] 85 dB(A) [1.5 dB]
Plug Fitted UK 3 pin plug
Web Attribute Set Fine Dust Extractors
EAN Barcode 5052511142118
