Arbortech TURBO Plane Blade
- Rapid freehand wood sculpting, planing and trimming
- Leaves a smooth finish requiring minimal sanding
- Durable carbide teeth ensuring long blade life even in hardwoods
- Easy to sharpen using a diamond 400 grit diamond file
- Excellent control, balance, and safety (no cutting teeth on blade periphery)
- Ideal for free-forming convex and concave shapes
- Fits Arbortech Power Carving Unit and any 100mm(4") or 115mm(4.1/2") angle grinder
- Can be used with guides and templates for accuracy
Empower your finish
The Turbo Plane is an amazing all-around blade that offers fast removal with great accuracy, making it ideal for creating flowing shapes and bowls.
Effortless sculpting
Shapes wood quickly and efficiently and provides a smooth finish, requiring minimal sanding. Perfect for rapid freehand wood sculpting, planning, and trimming.
Accurate control
Designed with no cutting teeth on the blade periphery, ensures precise and safe operation. This excellent control, balance, and safety make it ideal for all skill levels.
Durable performance
Tungsten carbide cutting edges ensure long-lasting performance and are easy to sharpen, making the blade durable even in hard woods.
Versatility
Perfect for flowing shapes, chair seats, bowls, detailed work and much more. Compatible with the Arbortech Power Carving Unit™ or any standard 100mm (4") or 115mm (4 1/2") grinder.
Smooth operation
The unique curved design and internal placement of wide cutting edges provide a smooth finish with minimal sanding, ensuring high-quality results with less effort.
The Arbortech TURBO Plane is a great addition to the very popular Arbortech range of products. Using this cutter is just like adding a rotary plane to your angle grinder. Proving very popular with woodcarvers and sculptors, the Arbortech TURBO Plane removes stock very quickly and leaves a great finish. Can be used on green or seasoned timber. The three durable tungsten carbide blades hold their edge well but can be easily sharpened using a diamond file when necessary. The 100mm diameter blade, attaches to the Arbortech Power Carving Unit and most 100mm(4") and 115mm(4.1/2") angle grinders.
EAN Barcode | 9313478320015 |
